My New spec on RS500
Air 2 air injectors with vari boost control
8 Greens
P8 ECU
Racing loom to run coil packs and some other tricks
BD14 ex standard Inlet cams
9:1 compression
Vern pullys
Cosmetic gaskets
KONI
Poly bushed all around
Samcos
Oil breather
O YER AND IT WILL BE SET UP BY
AHMED
TO FOLLOW AFTER
AP 6 Pots
Water injection
Ajust TCA's
BBS 17s
Dont knows
NOS got the kit but ???????????
ANYONE THINK WHAT I MISSED OR SHOULD DO?
8 Greens
P8 ECU
9:1 compression
Vern pullys
Cosmetic gaskets
KONI
Samcos
Oil breather
AHMED
TO FOLLOW AFTER
AP 6 Pots
Water injection
Ajust TCA's
BBS 17s
Dont knows
Heard a few bad things about the Cometic gaskets recently, although some people are still ok with them, up to you but I would be seriously considering the extra Ł200 for a genuine Mountune 4 layer WRC gasket!
Air 2 air injectors with vari boost control - Noooooo! Use a proper Jap "active" boost controller
8 Greens - OK......but peeps will point out that 4 big injectors is the way to go - I am starting to think that they are correct
P8 ECU - Again "quaint" old skool, depends on the above choice of injectors.
Racing loom to run coil packs and some other tricks -
BD14 ex standard Inlet cams -
9:1 compression - NO!
Vern pullys -
Cosmetic gaskets - NO! WRC only
KONI - OK
Poly bushed all around - OK
Samcos - OK(ish) there are others
Oil breather - Yes = Bailey
AHMED= sound
TO FOLLOW AFTER
AP 6 Pots -
Water injection -
Ajust TCA's -
BBS 17s -
Dont knows
NOS got the kit but ??????????? -
Vern pullys -
KONI - OK
AHMED= sound
TO FOLLOW AFTER
AP 6 Pots -
Water injection -
Ajust TCA's -
BBS 17s -
Dont knows
I would stick with the air to air injectors and have the boost curve properly mapped to suit
Nothing wrong with P8 and it can run big injectors (as can L8 etc - just ask Stu
Cam choice will make it responsive at expense of outright top end power
Compression seems way to high and will require loads of ignition retard (and resultant excess heat), so best to lower to what Ahmed recommends
.Nothing wrong with P8 and it can run big injectors (as can L8 etc - just ask Stu
).Cam choice will make it responsive at expense of outright top end power
.Compression seems way to high and will require loads of ignition retard (and resultant excess heat), so best to lower to what Ahmed recommends
Mike,
At TOTB 3, 31 cars in the top power (4x4) class....some very fast ones, some extremely fast ones...............
1. How many with Air to Air????
2. How many with Electronic Boost Controllers????
I dont know the answer, but I will guess at:
1. 0
2. 28 (i.e. ALL of the turbo cars)
1. 0
Originally Posted by St3V3_C
Shouldn't the WI come before the setup
IMO Water Injection should only be used as a backup safety thing incase somthing totaly unexpected happens, deffo shouldnt be used as part of the setup of making the car reliable when being driven flat out, that should be taken care of by a properly specced car and good fuel and ign mapping.
Doug,
Isn't that because the std Jap management systems wont integrate with stuff like air to air, where the overpriced Jap boost controllers are standalone in most cases......
You may well be right, but fitting air to air hardware/software/mapping is MORE expensive than most Jap boost controllers....and LESS flexable IMO.
Originally Posted by rs cos
mike probably doesn't sell jap electronic boost controllers doug, thats why they are shite!!!
I'ts just that when you use one of the very best engine builders in the business (for YB engines) and THE best mapper, you have access a very potent combination (SCS + Ahmed). You tend to listen to what they say/reccomend, in reality you devieate from what they spec at your peril!
So I can see where Mike is coming from
a lot of people still use the cometic gasket with no probs at all , i understand a few people had problems but this shouldnt really put people off cometic
i really think that you have the cams the wrong way round as well
can i ask how you have come up with that spec as it seems a bit "thrown together" no offence like
Doug and that is your best arguement?
Now narrow that down and tell me how many of these were running fully mapped / mappable ECUs with properly mapped boost curves?
. I know a few were (MoTec / Autronic).Personally, I would prefer my ECU to have FULL control of what is going on
.PS. I can / do sell Jap style boost controllers, but would always recommend that where possible to use the ECU to contol the boost.
The Cometic gasket that went on my car damaged the head and the block, there fore the head had to be completely stripped down and skimmed, the Block had to be removed and completely stripped down and also skimmed and it cost ALOT of un-nessesery money because of a faulty head gasket.
I WOULD NOT RUN THAT RISK AGAIN FOR THE SAKE OF Ł200 MORE ON A WRC GASKET
Just trying to advise people so they dont make the same mistake.
greddy boost controller all the way
you can set diffent boost curves for each diffent gear and it has data logger aswell
air injectors are over priced and your stuck with one boost curve unless you have a controller
as for your spec i would say old skool times have changed t4 waste of time small power band all over by 7500
money could of been spent better each to there own am not having a go
Originally Posted by Doug Stirling
Mike,
1. 0
1. 0
The BIGGEST difference was low down (at the onset of boost), responce and smoothness
Anyway, it was Harvey that told me that I should try an electronic boost controller............2 days later Simon fitted it
Brom are you using the profec A or B?
Just sold my Apexi avcr from the datsun as i figured it was a waste of time for a 3 dr (cant use the ECU dependant functions on AVCR), was gonna go for the profec B as a no frills boost controller...
Pectel just released a new ECU.............does it have facility to map for the fantastic state-of-the-art air injectors??????????
You tell me Mike
also i take it i can junk the AMAL valve with out the ECU spazzing out
The point I was making with WI was that it would not be right to bung in any old pump and jet and expect everything to be hunky-dorey...
Greddy B Spec II is the one I have - does exaclty what it says on the tin
Originally Posted by Karl
Personally I'd disagree with C.R, cam choice and gaskets.
As for air injectors I like them, and find that if properly mapped are excellent!
Without giving too much away, would the following be OK/safe?????????
C.R. 7.4:1
BD 16's in/out
"O" ring block and YB 1260 (late Es Cos gasket)
Can u explain what u mean pls, as i am looking onto one of these. As far as i can see it's got a high/low boost curve for every gear?
.......as allways you have a good argument BUT crucially you are out numbered by those that dont...........so YOU loose
