My New spec on RS500
Old 11-08-2004, 11:50 AM
  #41
TIFF
Chasing Radders
TIFF's Avatar
Old 11-08-2004, 11:51 AM
  #42
Ian2wdsaffcos
Ian2wdsaffcos's Avatar
Originally Posted by Ian@Racetek
9.0:1 compression + T4? .......tick.....tick.....tick
Cometic gasket on High Comp? Absolute faeces. Rhinoceros manure. Total camel excrement!
There speaks a man of experience I'd listen to him if I were you RS500/104!
Old 11-08-2004, 11:52 AM
  #43
Ian M500COS
Ian M500COS's Avatar
3-ply construction...... dried camel shit in-between tempered fag paper. Ideal for 4psi!
Old 11-08-2004, 11:53 AM
  #44
Karl
Norris Motorsport
Karl's Avatar
LOL @ Ian. Thats what I think about Cometic gaskets too but you're description was far better!!
Doug, that spec sounds fine to me.
Old 11-08-2004, 11:54 AM
  #45
TIFF
Chasing Radders
TIFF's Avatar
Old 11-08-2004, 11:55 AM
  #46
Rick
Rick's Avatar
Karl - get my txt about chip?
  #47
Ian M500COS
Glad to be of amusement Karl he he!! But the facts are true.
I would concur with Doug. Isnt it better to have 500bhp every day for a year than for a month?
Old 11-08-2004, 11:56 AM
  #48
RS500/364
RS500/364's Avatar
SO THE WEAKEST LINK IS
THE GASKET?
IT NOT A T4
I PUT A T34.63 HY ON THE SET UP
  #49
Rene
Rene's Avatar
please don't hold back Ian that's fookin funny!!!! me sides!!!
Old 11-08-2004, 11:57 AM
  #50
Ian M500COS
Trust me.... save up the extra Ł200.00 or it'll end in tears...or lower the compression. Put the 2 gaskets side by side and one looks like its made in Taiwan!!
Old 11-08-2004, 12:00 PM
  #51
Ian M500COS
WRC cars did not use Cometic gaskets. If your gonna go high comp, come down to about 8:5 or 8.6:1. Should be ok with T35 but try and save the extra and buy a proper gasket!
  #52
Ian2wdsaffcos
THE GASKET?
IT NOT A T4
You took the T4 off your RS500 & put a T34 on? First time I've ever heard of someone doing that! Everyone assumed you would still be on T4 cos it's an RS500 mate
Old 11-08-2004, 12:02 PM
  #53
Karl
Norris Motorsport
Karl's Avatar
The cometic gasket really is the cheapest of cheapest things. It should'nt even retail for Ł30 let alone over Ł100!!!!
As for C.R, I've said it before and it's fallen on deaf ears, but for a reliable road car (i.e. running on normal pump fuel) on a T4 at 500bhp you need to going for C.R below 8.0:1.
Old 11-08-2004, 12:03 PM
  #54
Ian M500COS
Couldn't agree more (now!)
Old 11-08-2004, 12:05 PM
  #55
rsnissan
rsnissan's Avatar
Originally Posted by Rick
cant use the ECU dependant functions on AVCR),
Can u explain what u mean pls, as i am looking onto one of these. As far as i can see it's got a high/low boost curve for every gear?
to get the most out of an AVCR you need to get a speed signal, RPM signal, Injector duty signal. On most jap cars you can splice into the ECU and get them not to sure about these on cossies which is why i am opting for a simpler controller. You need these electronic inputs for the self learing and Gear V's boost options. Not sure what signals are electronic on a cossie TBH
Most of the Big power jap cars run a profec B (no frills) over AVCR's which says alot i think. Not that i ever had a problem with the AVCR but that was on a lot less boost on a Datsun.
the other reason i didnt fit it was i think it will look a bit too out of place in an antiquated 3 dr dash lol
Old 11-08-2004, 12:09 PM
  #56
Rick
Rick's Avatar
Rpm Signal is straight from the coil, Speed sensor is easy - u can just use one that screws into the gearbox like on the fuel computers use. It just monitors the injector duty cycle - think thats optional if u dont do something else which i cant remember at the mo lol.
Old 11-08-2004, 12:14 PM
  #57
Rene
Rene's Avatar
would even 7.8:1 do enough ? for bigger power? as at the moment i got a 200 block with 4x4 pistons and a 2wd head which in combination should lower the CR.
So the only gasket you 2 advise is teh Mountune WRC one ?
Old 11-08-2004, 12:15 PM
  #58
TIFF
Chasing Radders
TIFF's Avatar
Dont even think about getting any other gasket, save fucking around and get a proper one
Old 11-08-2004, 12:17 PM
  #59
rsnissan
rsnissan's Avatar
you need a TPS as well which i think you should be ok with. You *may* be able to use the ABS for speed signal
  #60
Rene
Rene's Avatar
Indeed that's why i would never fit one as it doesnt fit with the dash yes i am being picky
Old 11-08-2004, 12:20 PM
  #61
rsnissan
rsnissan's Avatar
lol so its not just me i think i'll probably fit the profec discreetly or even hide the thing in the ashtray lol.
  #62
Rene
Rene's Avatar
about 380 quid wasnt it ?
Old 11-08-2004, 12:21 PM
  #63
Rene
Rene's Avatar
fit it in the coin tray
Old 11-08-2004, 12:23 PM
  #64
TIFF
Chasing Radders
TIFF's Avatar
Rene
Yes mate Ł380
Old 11-08-2004, 12:26 PM
  #65
Disabled Account
Disabled Account's Avatar
Tiff,
But looking at the post further up, you can see that Karl is not objecting to the relatively cheap alternative of "O" ringed block (Ł60.00 approx) + late Es Cossie h/gasket (Ł 20.00)...........Very easy to overlook that there were reliable 500 + BHP cossies LONG before WRC head gaskets were devised............Even Paul Baileys Escort (Mk2) with the usual 500 spec WON many races and continues to blitz allcomers on track days on an "O" ring blocked engine........
Old 11-08-2004, 12:29 PM
  #66
TIFF
Chasing Radders
TIFF's Avatar
Doug
Yes mate, there is that option too
But the WRC is more striaght forward
Either one will be fine BUT dont get a Cometic one
Old 11-08-2004, 12:36 PM
  #67
foreigneRS
Testing the future
foreigneRS's Avatar
what is an o-ringed block? :blonde:
Old 11-08-2004, 12:39 PM
  #68
3doorPete
3doorPete's Avatar
So if you were going for a Stage 3 rebuild, would Group A or Cometic Gaskets be better?
Old 11-08-2004, 12:41 PM
  #69
RS500/364
RS500/364's Avatar
THE GASKET?
IT NOT A T4
yes it is a 500 just the t4 is brand new wanted to try the 34 before i make the choice of the final turbo i like the t3 I KNOW I KNOW but the pick up is so quick
  #70
TIFF
Chasing Radders
TIFF's Avatar
Out of those 2 options i would get a Group A one as the Cometic gasket is SHITE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BUT
If you can afford a WRC one then get it
Old 11-08-2004, 12:44 PM
  #71
TIFF
Chasing Radders
TIFF's Avatar
You could always go for a "Low Lag" head from Norris Motorsport, Matt has a Low Lag engine built by NMS and on a T34 it makes full boost at 3200rpm, 32PSI i think.............Now that is a quick pick up
Old 11-08-2004, 12:51 PM
  #72
Rene
Rene's Avatar
how much is a grp a one then ?
  #73
TIFF
Chasing Radders
TIFF's Avatar
Ł60
Old 11-08-2004, 12:56 PM
  #74
Rene
Rene's Avatar
dilemma:
the Mountune WRC one is mega expensive - probably wont fuck up on any time
the Grp A one sounds fookin cheap - could be made out of plastic for that price
Old 11-08-2004, 12:59 PM
  #75
TIFF
Chasing Radders
TIFF's Avatar
dilemma:
To be fair, i think a few people run Group A gaskets on 330bhp convertions and they are ok with them, as long as the boost isnt too high.
BUT
After 330bhp i wouldnt bother getting a group A as you will be on Borrowed time.
DO IT ONCE, DO IT RIGHT
Old 11-08-2004, 01:01 PM
  #76
Rene
Rene's Avatar
dilemma:
BUT
true about that .. .glad i made the same decision a year ago with the block.
BUT my missus will kill me i i tell ill need a 380 quid HG and new headbolts!
Old 11-08-2004, 01:13 PM
  #77
Ima-Racing500
Ima-Racing500's Avatar
There is NOTHING wrong with cometic gaskets
Coopers rings...YES
I take it o-ring block means wire rung?
My professional advice mate ..RS500....Comp ratio is too high..dont do it 7.8-1 is perfect imo good off boost drivability too.Air injectors perfect.....not sure you need coil packs really.Cams...BD10'S
Old 11-08-2004, 01:20 PM
  #78
TIFF
Chasing Radders
TIFF's Avatar
There was with mine and it was proven to be a fault when it was made
Just advising people with my own experience Hopefully it will save them what i went through
Old 11-08-2004, 01:24 PM
  #79
Ima-Racing500
Not everything is perfect 100% of the time!I would imagine even a WRC one has had faults
I still say that the main problem with gasket failures is a mistake by the fitter.
Old 11-08-2004, 01:27 PM
  #80
Rene
Rene's Avatar
get your suit on boy
I dont know if you read tiff's problem with the cometic HG but i am sure that Karl knows how to fit a bloody HG!
Quick Reply: My New spec on RS500
