Ok honest answers please
If at all possible
From cold how many press ups can you do?Whats your age and weight?
Please dont pretend to be the worlds fittest as we WONT beleive you
PassionFords Creator
Well..
When i started my diet regime and weighed 17st 2lb i couldnt do 5 if im honest...
Now i can do 2 sets of 25 before bed with around 1 mins break in between..
Im 32 and weigh in now at 14stone 4lb.....
Originally Posted by Ima-Racing500
If at all possible
And why would anyone want to risk injuring themselves doing as many press-ups as possible without a warm-up first?
I do Circuit Training once a week
I'm just under 13 stone and 6 foot, age 26
i can do 40 from cold with no breaks......but during an hours class probably do a hundred or so with the same amount of situps, crunches, squats blah blah blah
I was crap when I started tho! Took about 4 weeks to get into it and keep up with the rest.....just old injuries that stop me doing it more often
Originally Posted by CabrioTurbo
up to 85-100 a night at the moment
surely it cant be! id DIE if i did more than 20
id have to change to 'girly' pressups where you kneel down
From cold it kills me, can do around 20 then have to change to something else though to give those poor wrists a rest for abit,,,lmao
I also get bored of doing them too,,,,,and I DON'T kneel down to do them either
I'm 25 and weight is around 7 & 1/2 stonne!!
fpmsl @ smit,,,,,
x x x
Originally Posted by Ryan
what are we talking here
define a press up???
if you think a pressup is when you nose or gut touches the ground your wrong
arm's at right angles is a press-up
2: 27 (holding on in there)
3: 11 stone ish, depending on whether I'm weighing myself before or after a weekend.
HTH
oh really,,,girlie ones ay,,,,pmsl
fpmsl @ smit,,,,,
fpmsl @ smit,,,,,
Ryan...like your salary you once said you had..BOLLOCKS
Ian.....i do em from cold..well i shake my arms about a bit first!
Interested to know....i can do 30 outright and weigh 14.5 stone 5ft 11
Apparently if you can do 40 plus outright you are very strong!
Weak is under 24...normal is 25 to 40
I come out of retirement re training recently and do 40 pressups a day along with 400 sit ups via that ab bar thing that dont fuck the back
...plus use a cross trainer.........
thinking about it i would class myself as reasonably strong.. as i can bench press a fair amount.. (more than most of my mates) but i can only do it a coupple of times
im propper knackered afterwards!
If you're actually doing the press-ups until failure then you risk injury by not warming up first.
Phil, Ryans way is for
's The further you go down the more of the muscle you use.
I would try but I went fooken extra in the gym on my chest last night and can barely move now, pmsl
's The further you go down the more of the muscle you use. I would try but I went fooken extra in the gym on my chest last night and can barely move now, pmsl
That is a rather misleading thing to say as there are 2 types of muscle fiber IIRC(power & endurance respectively). So if you have alot of Type 1 & not many of the Type 2 (ie. by genetics) then you will never be able to do a huge number of press-ups/whatever in comparison to someone who has loads of Type 2 & not many Type 1.
so there is actually some founding behind my excuse then!
Ian....they WORK.....i couldnt to sit ups thru lower back pains!This contraption allows me to work just the stomach muscles and boy does it feel like it works...i got a bit of a beer gut
but its rock hard past the flab
Ian...what i meant was if i did sit ups it would cause severe lower back pains...maybe i have a dodgy back?...BUT this thing is so good you can feel just the abs working,your lower back doesnt move!
