No spark on RS1800
Old Jun 11, 2006 | 11:38 AM
Maltese Andy's Avatar
Maltese Andy
Default No spark on RS1800
Hi guys,
recently i stripped my Fiesta RS1800 to a bare shell, including the loom for a respray. the engine started with no problem before that. Now i put everything back together again, all the electrics/lights work, the fuel pump works but there is no spark on the HT leads, hence not starting.
Any ideas?
cheeRS
Andy
Old Jun 11, 2006 | 12:35 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
then your coil pack has fooked i should imagine. swap that over 1st and see. as thats the easiest
either that, crank sensor or some wiring is faulty
or how about an alarm/immobiliser?
Old Jun 11, 2006 | 01:42 PM
Maltese Andy
When i bought the car it did have an alarm which didn't work so when i stripped the loom i removed every wire belonging to the alarm and re connected the factory wires in their original way.it was quite simple. is there some sort of immobiliser?
Old Jun 11, 2006 | 06:04 PM
pollocks's Avatar
pollocks
yes there is an immobliser called the pats system which runs off the chip in the key fella
i aint got a clue on how it works but i know its there on the rs1800 or at least i think it is lol
Old Jun 12, 2006 | 07:01 PM
Maltese Andy
Problem solved,
it was the crank sensor. Changed it and it fired up immidietly. cheeRS guys.
new smaller problem now,
the engine seems to be turning the selfstarter. it can be heard wining.
must be the solenoid stuck
Andy
Old Jun 13, 2006 | 11:34 AM
Oranoco's Avatar
Oranoco
Happy to have helped mate
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
Brian
Sep 11, 2015 08:06 AM
