No spark on RS1800
No spark on RS1800
Hi guys,
recently i stripped my Fiesta RS1800 to a bare shell, including the loom for a respray. the engine started with no problem before that. Now i put everything back together again, all the electrics/lights work, the fuel pump works but there is no spark on the HT leads, hence not starting.
Any ideas?
cheeRS
Andy
Any ideas?
cheeRS
Andy
then your coil pack has fooked i should imagine. swap that over 1st and see. as thats the easiest
either that, crank sensor or some wiring is faulty
or how about an alarm/immobiliser?
When i bought the car it did have an alarm which didn't work so when i stripped the loom i removed every wire belonging to the alarm and re connected the factory wires in their original way.it was quite simple. is there some sort of immobiliser?
yes there is an immobliser called the pats system which runs off the chip in the key fella
i aint got a clue on how it works but i know its there on the rs1800 or at least i think it is lol
Problem solved,
it was the crank sensor. Changed it and it fired up immidietly. cheeRS guys.
new smaller problem now,
the engine seems to be turning the selfstarter. it can be heard wining.
must be the solenoid stuck
Andy
Andy
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
