help help gti wiring on engine swap
Old Jun 10, 2006 | 06:51 PM
ilovestacey's Avatar
ilovestacey
Default help help gti wiring on engine swap
hi iv just taking my 1.8 mreg si efi zetec engine out of my mk5 due to it blowing up iv got a 1.8 gti that iv put in that i have the correct wiring loom for wen i came to fit the engine i found my wireing loom was different wat shud i do change the loom or shud i use my efi inlet and old loom and go for dat i rele will i lose alot of power from the gti engine if i use the efi inlet andthotle body
Old Jun 10, 2006 | 08:10 PM
reality's Avatar
reality
If they're both zetecs, i'd take everything from the old engine and bolt it onto the new one.. plug and pray..
Old Jun 10, 2006 | 08:58 PM
ilovestacey
Default efi injection
wat take the efi unit off and use my old injection and old wiring loom then and do away with the gti injection system will it lose power off the gti if i do that or nt thanks
Old Jun 10, 2006 | 09:19 PM
reality's Avatar
reality
If they're both 1.8's, it'll be the same.. The Si is apparently 105PS and the GTI is 115PS.. I doubt you'd notice the difference..
Old Jun 10, 2006 | 11:14 PM
robbyridz's Avatar
robbyridz
my Si had 115ps, but I plugged and prayed with the 130ps efi manifold & 2L throttlebody... and I noticed a big difference, I just hope ECU makes a difference aswell!
I've been in a 105ps si and it seemed slow compared to even 115ps one
JoeyBoyden
Jan 4, 2024 02:36 PM
Kyle Langford
27
Aug 5, 2019 07:54 PM
muz
Aug 16, 2015 12:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
