Confirm my suspect head gasket.....plz(leak results)added
Old Jun 8, 2006 | 03:38 PM
biglee's Avatar
biglee
Audio specialist
Default Confirm my suspect head gasket.....plz(leak results)added
ok so i went to brunters.....all was going well until...pink pink pink...
since then i have had foam in the header tank and i have a very very pressurised water system......super solid hoses...
i was wondering what people think before i go rippin it all to bits...again,
cvh turbo S1 by the way...
cheers.
Old Jun 8, 2006 | 03:58 PM
SafeChav's Avatar
SafeChav
Has to be, can't be a lot else.......
Old Jun 8, 2006 | 10:09 PM
biglee's Avatar
biglee
Audio specialist
ok so ive been to JEMS and had a leak down test done on a hot engine, results were:
cyl 1.....@180 psi....leakdown less than 5% over 5 mins
cyl 2.....@180 psi....leakdown less than 5% over 5 mins
cyl 3.....@180 psi....leakdown less than 5% over 5 mins
cyl 4.....@180 psi....leakdown less than 5% over 5 mins
so ...he says it is perfect......dont understand
why would i get a charged water system? if its all ok ..
Old Jun 9, 2006 | 10:19 AM
SafeChav's Avatar
SafeChav
Oh dear.............
Cracked head?
Cracked block?
Old Jun 9, 2006 | 08:10 PM
costina's Avatar
costina
Live long and prosper!!
Cracked turbo housing
could give you the same symtoms
Old Jun 10, 2006 | 01:40 PM
biglee's Avatar
biglee
Audio specialist
Cracked head?
Cracked block?
leakdown test shows these up...so i guess not, turbo housing may be cracked, i will disconect the water to the turbo and see if it does it...
Old Jun 10, 2006 | 01:49 PM
SafeChav's Avatar
SafeChav
If it was the turbo housing it would be mixing oil and coolant.............
Old Jun 13, 2006 | 01:01 PM
NIMRODS_RST's Avatar
NIMRODS_RST
MISSING MY RST!!
u broke it again lee!!!!! lol
Old Jun 15, 2006 | 01:50 AM
biglee's Avatar
biglee
Audio specialist
ok so ive drained my water and re-filled it with 50-50 mix summer coolant and...its perfectly fine
went out for big thrash and all is well......
HOW WIERD IS THAT .....LOL
Old Jun 15, 2006 | 03:14 AM
TURBO BOI's Avatar
TURBO BOI
Must have been a air lock
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
