dumpvalves
Old Aug 9, 2004 | 04:59 PM
joo5t's Avatar
joo5t
Default dumpvalves
This is posted on http://www.eil132.com/8.html, is it true ?
Dump Valves
Let's get one thing straight, RST's don't need dump valves. They don't do anything for them. No anti lag, no extra turbo life, nowt. On an MFi set up your more likely to have problems than sound like a bus, which is what most people buy them for! Because the KE Jetronic system has the airflow meter before the turbo, the dump valve can draw in air resulting in idle/leaning off problems. Do yourself a BIG favour and don't bother buying one unless noise is all you are interested in. Even on a Cosworth it's only really needed when using a T4 turbo or bigger. It's a big con! Use your money elsewhere.
Old Aug 9, 2004 | 05:05 PM
JamesH's Avatar
JamesH
He's on this site........
Old Aug 9, 2004 | 05:16 PM
Stu.H's Avatar
Stu.H
others will say different when running 1bar or more on RST
Old Aug 9, 2004 | 08:12 PM
Oranoco's Avatar
Oranoco
Spot on.
A dump valve on an ERST is a waste of time and usually causes problems. I speak from experience. I lobbed my dump valve into my spares box a while ago and have never looked back
Even with 25psi of boost the bugger won't be going back on the car
Old Aug 9, 2004 | 08:16 PM
McPikie's Avatar
McPikie
I took mine off my cab. The car was gay enough without it. With it, all I needed was a hairband and some sizzors
Old Aug 9, 2004 | 08:19 PM
Jim Galbally's Avatar
Jim Galbally
thats all correct when talking about 99% of ERSTs out there...
seriously mate, all they do is make a noise... the car will drive better without it
Old Aug 9, 2004 | 08:44 PM
wimwerf's Avatar
wimwerf
a DV is good for the bearings of the turbo when they are running enough boost.
it could take of the strain from the bearings.
Old Aug 9, 2004 | 08:56 PM
RichardPON's Avatar
RichardPON
The guy who writes on that site chats so much shit it's untrue........................
Old Aug 9, 2004 | 08:57 PM
EIL132's Avatar
EIL132
Old Aug 9, 2004 | 08:59 PM
McPikie's Avatar
McPikie
wapster's Avatar
wapster
here we go
Old Aug 9, 2004 | 09:00 PM
Oranoco's Avatar
Oranoco
Gott alove these new smilies
Old Aug 9, 2004 | 09:34 PM
mybluechicken's Avatar
mybluechicken
Isn't a DV supposed to be good for the turbo's life? So why yes on one car and not on another?
Mr.Ford
Ford Escort RS Cosworth
Apr 4, 2005 12:07 PM
Stavros
Jan 4, 2005 02:11 AM
wimwerf
18
Sep 24, 2004 12:50 PM
wimwerf
41
Sep 14, 2004 12:31 PM
M2YLE
Sep 12, 2004 09:48 PM
