is my D/V knackered?
Old Aug 9, 2004 | 02:05 PM
CabrioTurbo's Avatar
CabrioTurbo
Default is my D/V knackered?
Notice the other day that my dump valve has only started to work half the time
When i give it some and then let off the gas, sometimes it will dump pully.. other times it will dump a little and chatter and sometimes will will just chatter... ie no ptish at all propper confused! is the D/V fecked.. i have noticed my idle has gone a bit low however i cant find any splits in the hoes themselves and the clips are done up nice and tight!
Also the vacum feed off the dumpvalve seems fine and isnt blocked in anyway..
Any ideas! pls
Phil
Old Aug 9, 2004 | 02:07 PM
Physio's Avatar
Physio
Phil, have you checked the rubber cap inside? (depending on what d/v it is) It's only got to have a slight hole in it & it wont work propperly mate.
Old Aug 9, 2004 | 02:09 PM
CabrioTurbo
sorry! forgot to say its a baileys doubble piston thingey
Old Aug 9, 2004 | 02:11 PM
Jim Galbally's Avatar
Jim Galbally
take it apart... check it for damage, then put it back together again
Old Aug 9, 2004 | 02:12 PM
Physio's Avatar
Physio
:gayflag:
I would have suggested checking all the clips, hoses etc but you've already done that
Old Aug 9, 2004 | 02:13 PM
McPikie's Avatar
McPikie
Take it out, replace with broom handle, be more manly
Old Aug 9, 2004 | 02:17 PM
CabrioTurbo
Ill never get it back together agian
Looks like i might be doing that! i do like the 'toilet flush' though
Old Aug 9, 2004 | 02:18 PM
Jon ERST S2's Avatar
Jon ERST S2
whats the boost doing on the boost guage?
McPikie's Avatar
McPikie
Team Turkey is the way forward.
I dont have a dump valve on mine
Shit, its not a turbo is it
Old Aug 9, 2004 | 02:24 PM
CabrioTurbo
Boosting to.. and holding a massive 14 Psi
Old Aug 9, 2004 | 02:35 PM
Jim Galbally
when booting the DV is being forced shut so its not replying on spring tension alone
Old Aug 9, 2004 | 02:37 PM
Lee Reynolds's Avatar
Lee Reynolds
Remove, and ebay the scrap d/v
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
3drRich
Sep 13, 2015 07:32 PM
