THOUGHT I HAD SORTED IT BUT NO NO NO NO
Old Jun 2, 2006 | 04:26 PM
vinnyd's Avatar
vinnyd
Default THOUGHT I HAD SORTED IT BUT NO NO NO NO
hey ppl i thought i had sorted my starting problem on the cossie, i replaced the two wires from the crank sensor and it started, but onec i put them neat in the loom the same problem has happend...AAAARHHHH..
i done that check test on the ecu plug, but i am not getting a voltage from the trigger wires which go to the ignition amp module, plus when i short them out i do not get a spark whch it should do if its done manually!!
does anyone know or could try this for me, i am just trying to see if the LED tester would bring a crank fault up if the module doesnt work!!
cos there is no fault code for the module so i am assuming that it will bring the next thing up what it cant see???
cheers..
Ian1964
12
Jan 26, 2021 11:57 AM
TPM961
Jan 15, 2018 10:50 AM
Fiddy
21
Sep 29, 2015 06:10 PM
gcfcos
88
Sep 15, 2015 03:48 PM
