using a 3i fuel pump?will it work
will using a xr3i fuel pump on an rst work?
would it let it idle and not be enough fuel on boost or will it make it run like a bag of shit from the start
mates just converted a 3i to rst spec and he's havin trouble gettin it to idle,could the fuel pump be the cause?
Ive heard that aswell, but there was a thread a few weeks ago. The RS and XR have the same pump, and then people fit cossie pumps as uprated items which have a higher flow rate, but are identical to look at. I'll try and find the thread.
A vacuum gauge is an invaluable item on an MFI. Air leaks can make them sound as if they are mis-firing and they hunt and sound like a scooby. Is the mixture screw covered over?
Originally Posted by SafeChav
Pumps are the same mate.
If its struggling to idle then i can almost guarantee theres an air leak.
Brake servo's are prime suspects believe it or not
I wasn't sure of this, but theres another thread where someone quoted me the Bosch numbers etc and said they were the same. I'll have to dig the thread out
[quote="SafeChav"]
xr3i pump are different to an rs. xr3i only runs 2.5 bar static presurewhen an rst is 5 bar presure
I am sure my autodata cd shows this too, ill scan in a copy and post it up.
could this cause a misfire?
cheers for the info
cheers for the info
both have different parts numbers for the fuel pumps
Guys,
I had a chack on Auotdata, The XR3i pump delivery pressure as below
is just suplying enough pressure to run the turbo. Turbo below
In theory a 3i pump is ok for a limited time as if the pump was to drop below is maximum you could have reduced fuel then a lean condition then bye bye pistons!
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
