xr2i Thermostat Help
Old May 28, 2006 | 08:54 PM
tashxr21's Avatar
tashxr21
Default xr2i Thermostat Help
Hey there...
I've recentally brought an XR2i 8v......
Everything was running fine for the first few days..... Then took it out the next day, Everything was running fine until i parked it on my drive then the smoke started to come from the engine....
I looked under the bonnet to fine that my oil was fine but my coolant levels had dropped alot ... i looked over the engine then i found the problem ...
I seem to have a hole in my theromostat ...... And alot of the coolant seems tobe pooring out of it ...
I have had a friend look at it and my other half and it seems to be that either a plug or something has come out and it also seems to us that there is a valve .....
Can anyone please help me ....
Old May 28, 2006 | 09:01 PM
SafeChav's Avatar
SafeChav
Wheres the hole mate
Old May 28, 2006 | 09:09 PM
tashxr21's Avatar
tashxr21
its on the silver bit near the top about half way across
Old May 28, 2006 | 09:12 PM
SafeChav's Avatar
SafeChav
Ok, are we talking red circle or green circle?
Old May 28, 2006 | 09:15 PM
tashxr21's Avatar
tashxr21
its the red circle
Old May 28, 2006 | 09:17 PM
SafeChav's Avatar
SafeChav
lol, dont be embarased. I did that cos i could see some white staining in the green circle, thought maybe it was cracked.
OK, that should have a very tiny core plug in it, i duno if you will find one that small of if its even worth doing, you can just as easily put a new housing on, 3 x 10mm bolts. However you do run the risk of them snapping which they like to do.....
Old May 28, 2006 | 09:20 PM
tashxr21's Avatar
tashxr21
thanking you ..... i shell take a trip to the scrappy.... or buy a new core whats it
Old May 28, 2006 | 09:31 PM
SafeChav's Avatar
SafeChav
Originally Posted by tashxr21
spanking you ..... i shell take a trip to the scrappy.... or buy a new core whats it
I beg your pardon
Welcome by the way
Old May 28, 2006 | 09:37 PM
tashxr21's Avatar
tashxr21
Lol.. Thanks mate
Old May 28, 2006 | 09:52 PM
SafeChav's Avatar
SafeChav
No problem.
Just looking at that picture again, it looks like the core plug is still in there, but they are galvanized steel so they are always the weak part (the housing itself is cast aluminium)
Another housing will probably be the best way, although i would out a new thermostat in aswell while its off as they are notoriously crap on CVH's. Halfords, about Ł3.49
Old May 30, 2006 | 05:15 PM
tashxr21's Avatar
tashxr21
we have tried our local scrap yards and local shops and no luck .... we have been told a place in manchester has one for 10 pounds is there any where we can get one before Friday .....
*Pulling Hair out*
Please Help
Old May 31, 2006 | 08:23 AM
SafeChav's Avatar
SafeChav
Hi.
Theres millions down our local scrappy.......
I'll get you one off today and send it to you for that if you like?
Old May 31, 2006 | 12:33 PM
Avinitlarge's Avatar
Avinitlarge
Drill it, Tap it the put a short bolt in it, Use some PTFE tape on the treads of the bolt, Jobs a good un
Old May 31, 2006 | 03:55 PM
fiestaturbo1984's Avatar
fiestaturbo1984
or as andy said a new thermostat
for the sake of a tenner its better to replace than repair
Old Jun 8, 2006 | 09:44 AM
tashxr21's Avatar
tashxr21
Thanks for the help guys i havent been on here for a bit ....bUt the problem is now sorted my friend had one of his old RS in his shed so we popped iton mine ... Its all been checkd and i can acctually drive it now
So thanksagain!!!!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
The Enigma
Sep 29, 2015 10:31 AM
Andypandy260
Sep 23, 2015 10:28 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
