ZVH or ZETEC TURBO
ive always planned on fitting a 2.1 ZVH into my s2 when i rebuild it but ive been thinkin of a zetec turbo!whats involved in building a zetec...also will it run OK on EFI?
also the benefits of either engine compared!
Zetec is the better way! It's much work to build a ZVH and it the parts needed for the bottom end can also be used for the Zetec. And it benefits from its 16V. EFI won't work unless you use RST EFI. The only problem on the 16V is to get an exhaust manifold. Just put enough money in, buy a Weber Alpha or something else and have much fun with a 16V
yeh thats what im thinkin more power poential but im also considering cost what are the costs with zetec? i already know what costs are involved with ZVH but i dont know much bout zetec turbos!
Back to the managment will a zetec run ok on OFAB EFI?
go full zetec to get a zvh to produce the goods takes alot of money better off going zt far easier and probably cheaper and this is from someone who has spent loads on a zvh.
Originally Posted by Tim
Im biased and say cvh had a little power run yesterday after a few tweeks she made a bit of improvement lol.
what boost was that @
Are the parts for a zetect T easy to get hold of?who supplies them? Also what parts are any good? The heads are meant to breathe really well of he Zetecs arent they?
As the old saying goes "there is no replacement for displacement".
Why go for 1600cc when you can have 25% more capacity??
If you want a good example of what you can do with a stock zetec and a gt28rs check out this link.
http://www.westfield-turbo.co.uk/specification.htm
No expensive steel internals here and a power sheet from the same chassis dyno!
can i but in here for a sec........cheers
I was considering the same thing but i dont want to fuck around with the originality of my S1 so i was thinking of ZT bottom end so i could keep the CVH layout, that way i can take it to 2.0 without an overbore. either that or PE 1.9 convo
Any thoughts guys?
Any thoughts guys?
I was thinking of using the zetec (from my mondeo)but been told that you really need an rs2000 box and new driveshafts to make the most of it??? so im staying 1600 and going to get cossie managment. Also its just slot straight in and no worries about anything else. it also says 1.6 on the block and thats rather useful to me for insurance reasons
Tim
What was the score with the duratec? pro's and cons way of course?
Ive got a cracking 1600 cvh in there just now which is getting a map session on saturday and im hoping a can crack past the 230 mark with a few tweeks, then once the wee body bits are sorted (which aint much btw) i want to get some more power and as i said above a fancied the zt caper but dont want to stray from the cvh since its an S1.
Stage 3 head will be next but getting above the 230 which i should currently have is there any recomendations?
stuart collins
Top spec mate
stuart collins
Top spec mate
