Lost Boost
Old May 17, 2006 | 03:12 PM
Robmk6's Avatar
Robmk6
Default Lost Boost
hi guys just wondering what this could be, as have put it down to a knackered actuator but also have another theory on a stuck wastegate but i have lost all boost.
Has been on and off for a month now where it was only boosting to .2/.3 bar, then it would suddenly come on boost.
I took it to FITP sunday (250 mile each way) and it was fine, but took it out for a run to town yesterday and after 6 miles lost all boost,
any ideas what this could be?
cheers fellas.
and whilst on the subject of actuators what do the numbers represent?
18, 22, 31 etc?
Old May 17, 2006 | 03:18 PM
Rick's Avatar
Rick
if u have no boost, the wastegate must be at least partly open. Sometimes they don't seat properly. Best taking the elbow off and having a look. The -18 etc are partnumbers - they have different lift off pressures.
Old May 17, 2006 | 11:18 PM
Robmk6's Avatar
Robmk6
well the whole lot is comin out as i have another bottom end to go in but will look then,
does anybody have an actuator for sale by any chance?
Old May 18, 2006 | 01:23 PM
Rick's Avatar
Rick
ians2rst - posts in RS Turbo bits for sale section - will have.
Old May 19, 2006 | 12:02 AM
Robmk6's Avatar
Robmk6
cant reply in there as im not a gold member.
Old May 19, 2006 | 12:08 AM
Robmk6's Avatar
Robmk6
seems i should try before i post,
pmsl
Old May 19, 2006 | 08:02 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I recently had the problem that my Standard S2 was only boosting 3 psi.
Then I checked all the common troublemakers
- actuator (length and spring)
- amal valve
- searched for air leaks
- etc.
But finally it turned out to be a faulty ECU. After changing it, it boosted 7 - 8 PSI again. Maybe the vacuum sensor in there was knackered.
Old May 19, 2006 | 08:06 AM
user 7082039239
Also, check the plug that goes to the amal valve. They tend to slip off.
Old May 19, 2006 | 03:26 PM
Robmk6's Avatar
Robmk6
yeah amal valve and all the basics like air leaks i've gone over, still nothing
Old May 19, 2006 | 03:52 PM
JimmyBoy's Avatar
JimmyBoy
Should be able to reply m8, just not start a topic.
Old May 19, 2006 | 04:12 PM
Robmk6's Avatar
Robmk6
realised that hence above post, pmsl
Old May 19, 2006 | 04:20 PM
JimmyBoy's Avatar
JimmyBoy
ahhhhh! lol
Old May 19, 2006 | 06:24 PM
user 7082039239
Try another ECU!
Old May 19, 2006 | 06:32 PM
Robmk6's Avatar
Robmk6
mines chipped tho
Old May 19, 2006 | 07:01 PM
user 7082039239
Wait a minute. When my ECU was damaged it only boosted around 3 PSI, but it boosted. Have you really lost ALL the boost? Then you should have a look at the waste gate first.
Old May 19, 2006 | 07:03 PM
SafeChav's Avatar
SafeChav
I had the same problem on mine, NO boost at all.......
Then when i remembered to connect the actuator to the wastegate it was all good
Old May 19, 2006 | 09:03 PM
Robmk6's Avatar
Robmk6
all is connected
and yes i have NO BOOST AT ALL
Old May 19, 2006 | 10:06 PM
SafeChav's Avatar
SafeChav
Can you even hear any boosting from the turbo or is there silence?
Old May 19, 2006 | 10:14 PM
turbo.jon's Avatar
turbo.jon
Ive got same prob here got no boost at all and you can hear turbo is not even spinning think ive narrowed it down to the actuator rod being to slack but will find out if it sorts it out tomorow
Old May 19, 2006 | 10:19 PM
SafeChav's Avatar
SafeChav
If thats the case it has to be wastegate related or in very extreme cases theres a possibility of snapped/seized shafts.
Old May 19, 2006 | 10:30 PM
turbo.jon's Avatar
turbo.jon
with mine ive just had the turbo housing off as had a bolt snapp when i put it back on think it was a little out to what it was before so the actuator rod is very lose but still connected so this is leaving the wastegate open all the time....well this is what i hope but will find out in morning
Old May 20, 2006 | 09:25 PM
Robmk6's Avatar
Robmk6
if it had suddenly stopped i would expect a snapped shaft yes, but its gone over a period of time, boosting, not boostin, crap boost then all of a sudden absolutely flying... so when i get time om gonna have to check the actuator,
Old May 20, 2006 | 11:13 PM
SafeChav's Avatar
SafeChav
Indeed a snapped shaft would be a sudden stop, as i said that is very extreme cases, yours isn't likely to be that but don't overlook it
Old May 21, 2006 | 10:38 PM
Robmk6's Avatar
Robmk6
cheers for the help fella, much appreciated!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
Russ Payne
Sep 25, 2015 08:29 PM
