problem with the gearbox
this weekend i put another gearbox on my s2 and put 1l of 80w90 gearbox oil in it ( it was sunday and 1l was al i had )
now i drove it like this fore 2 day's
thuday i put in another 2 l and now i can only shift into 3 and 4 ( hard)
1,2,5 and reverse are allemost impossibel?????
( help)
sorry for my english
grtz from belgium
( help)
grtz from belgium
Depends on what mileage you did on it in the 2 days when it was low on oil.
Are you sure the selector rod on the gearbox (underneath) hasn't come loose ?
Welcome to Pf by the way
Your English is fine
but your chocolate and beer is better
Maybe the Linkage has not been setup right.
I select Reverse on the box and then put the linkage onto the shaft of the box.. Hold the gearstick in the correct place reverse should be and lock it in place. Works for me!
thanks
i did about 150km with (100miles)
but the gearbox was fine a minut before i put the other 2 l in
i chekt the selector rod it was fine i even took it of and tried selecting gear with the rod from the gearbox and it almost had to hit it with a hamer to push it back
yes beer and chocolate are great here
( i think i am the only belgen that do'snt like beer
i haven't chect the breather yet but i tried to move the selector rod with the filling plug off so air wouth get out and it still had no effect
i think i'm going to have to change it again
( the glory of a s2 a guess
would an ib5 box fit without problems?
grtz
)would an ib5 box fit without problems?
grtz
TPM961
Jan 15, 2018 10:50 AM
