A few points.
Old May 16, 2006 | 07:02 PM
donny murdo's Avatar
donny murdo
Default A few points.
I got my first RS a couple of months ago (escort rs turbo) I'm very happy with it, except for the brakes which are fookin frightening, a not uncommon problem! they are standard.
The main thing is a horrendous shuddering through the steering wheel under heavy breaking
Having spoke to a few people about this and with a limited budget, and not knowing very much about rs modifcations, am I best to go for cosworth 2wd discs, with a bracket for the standard calipers? if so do I get ford discs or for example EBC, or what?
Pads? Whats best to use your advice and help would be appreciated.
Also I would like to give it a service, change the oil,(do i use synthetic, semi, fully ? plugs, air/oil filter.
Which bits should I use and where to get them?
Thanks alot in advance
I
Old May 16, 2006 | 07:30 PM
notSteveS2's Avatar
notSteveS2
get 2wd discs and cossie 4x4 calipers.... dont scrimp on brakes mate...
oil filter from fords...
15w/50 mobile 1 motorsport oil from halfords...
Old May 16, 2006 | 11:15 PM
Dan's Avatar
Dan
Disc's must have warped mate? You've not had the car 5 minutes from Danny have u?
Old May 17, 2006 | 06:39 AM
donny murdo
TBF it was like that when I bought it, would like some advice about what to replace them with!?
Old May 17, 2006 | 09:49 AM
ballin's Avatar
ballin
is this my old one mate?
looks like it!
i would put 2wd discs + 4x4 callipers on, thats what i had all ready and lined up before it went
Old May 17, 2006 | 10:13 AM
SafeChav's Avatar
SafeChav
Try swapping wheels around before you change your brakes, its very common on escorts for discs to warp but its not always the case.
Old May 17, 2006 | 11:09 AM
donny murdo
Yeah thats the one!
Spoke to you a while ago about it, brakes need sorting sharpish just trying to get some ideas from people
Old May 17, 2006 | 01:54 PM
ballin's Avatar
ballin
thought that was you, couldnt remember username exactly
like i say mate, cossie setup is what i was going for, just bought a set for Ł200 all in which aint bad.
depends how good your calipers are really - you may get away with just fitting the 2wd discs and getting some brackets off www.randbmotorsport.co.uk and keeping std calipers.
otherwise get em reconned - im not sure on their condition never checked
Old May 19, 2006 | 10:03 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Don't forget to upgrade to braided lines and dot 5.1 fluid too
Sounds like warped disks but i hope the wheels aren't buckled - damn roads around here, worst in Britian
FlashBastd
Feb 8, 2015 05:30 PM
cutch
Sep 3, 2010 08:44 PM
chappers
Jun 4, 2009 05:46 PM
BLACKCOS
21
Nov 20, 2008 07:01 PM
mikee_rs
Aug 6, 2006 01:21 AM
