Cosworth engine + remote servo
Old May 15, 2006 | 04:46 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Cosworth engine + remote servo
Hi I am using a cosworth engine for a project, does anyone no where I can connect a remote servo vacuum pipe in? I know I need a one way value. Any pictures greatly appreciated. Many thanks.
Old May 16, 2006 | 06:48 PM
killerscum01's Avatar
killerscum01
Hi, when we did a transit cossie we took out the breather pipe fitting from the inlet plenum and screwed in a hose barb and yes you will need a non return valve, and 3/8" id pipe works best. Then just vent the breather on the block to atmospere.
Hope this helps.
Bart
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
