Oil Pressure Light
Old May 9, 2006 | 02:27 PM
PeteS2RST's Avatar
PeteS2RST
Default Oil Pressure Light
Just bought a G plate Seriries two and after changing Oil and filter when the car idles the oil pressure light flickeres on and off and if left at idle for 30 seconds or so it comes on permanently and the engine sounds a bit tappetty as soon as you blip the accelerator it goes out but comes back on as soon as it returns to idle.
it had a split breather filter but this was replaced when the oil was changed there are no other obvious leaks and i used 10w 40 magnatec oil.
Any ideas
Old May 9, 2006 | 02:41 PM
SafeChav's Avatar
SafeChav
Sounds like the pump could be on its way out
This is where an oil pressure gauge is quickly evident its the best Ł40 you can ever spend............
Old May 9, 2006 | 04:12 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
say bye to your shells
if you catch it soon enough teh starvation wont affect the head too much, big ends gonna need a build tho, ive had a few do this and the cranks dont take much before being scored up and needing a grind
Old May 10, 2006 | 09:44 PM
HORNETS7's Avatar
HORNETS7
hmm try changing the oil pressure sensor first ! and as said above try testing the oil pressure! see what u get!
also if the engine is struggling on tick over this will cause the light to come on!
Old May 11, 2006 | 05:22 AM
PeteS2RST's Avatar
PeteS2RST
Fitting oil pressure guage tomorrow Thanks ALL for your help.
Old May 11, 2006 | 08:35 AM
SafeChav's Avatar
SafeChav
U won't regret that
Old May 26, 2006 | 07:58 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Had a similar problem on mine! There is a small one-way flap at the oilcooler. On mine it was jammed closed. Just take a screwdriver and open/close it manually a few times. Should work then.
BTW: Realized that after changing oil pump and checking the main/big end bearings...
Old Jun 1, 2006 | 11:00 PM
DaveN's Avatar
DaveN
THATS HAPPENING ON MINE AND SHELLS PUMP AND WHOLE BOTTOM END HAS BEEN RECOND M8. AND NOT ONE GARAGE IVE BEEN TO IN MY AREA CAN SOLVE THE PROBLEM.
Old Jun 2, 2006 | 09:37 AM
ivorbiggun's Avatar
ivorbiggun
2 daft questions....
1,is there enough oil it?
2,did you mistakenly switch to a lower viscosity oil?
Old Jun 2, 2006 | 11:56 AM
C14KEE's Avatar
C14KEE
mate your oils shit.
dont know about the other problems but get 10w50 and keep an eye on it.
cheapest place to start
Old Jun 2, 2006 | 01:11 PM
PeteS2RST's Avatar
PeteS2RST
Cheers to all above have replaced all vacuum hose and removed dump valve and idle is now bang on light coming on is a thing of the past for now at least
Fingers Crossed
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
