help me:)
91' FRST
At 16psi as it reaches the 6200-6300rpm, the car slows down, rpm falls down to 5000,
and the pressute too. It exists until I step off the gaspedal.
If the pressure is higher, this symptom appears sooner:
18psi-> 6000rpm
20psi-> 5500rpm
Why does it happen?
What can I do, because i wanna use my car on 20psi?
spec:
1.6 low comp Mahle
superchips(unlimited boost)
FMIC
denso racing fuel pump
305ccm injectors
champion QC59C
T3 stage3
thanks for your help
18psi-> 6000rpm
20psi-> 5500rpm
Why does it happen?
spec:
1.6 low comp Mahle
FMIC
305ccm injectors
champion QC59C
T3 stage3
Originally Posted by h196jne
Somebody correct me if i'm wrong but even if its chipped the rev limiter will kick in yes???? and going that far up the range
no rev limiter
Mine rev'd to 7k on the rollers so I think it's safe to say mine doesn't have a limiter anymore either.
Put simply mate you're over reving the car. Learn to use your gearing as there is no need to rev that high and no benefit to be had
Originally Posted by bluebones
lets get this right... an OFAC is boosting more than 16psi.?? i thought this was not possible as the map sensor wont let you.. as its only ofab you can do this...
next exchange 0FAC for 0FAB.(3bar map)
21
Dec 16, 2004 01:30 PM
