fuel rail welding???
Old May 6, 2006 | 06:53 PM
gibbo frst's Avatar
gibbo frst
Default fuel rail welding???
hi all.. how can i fit an ally screw on fitting for braided fuel lines onto the original fuel rail?? i had an old rail what i threw away that looked as if the screw on fitting had been welded or braised.. can this be a diy job for me if so what do i need or off to a garage...? cheers
Old May 6, 2006 | 07:07 PM
DAN P's Avatar
DAN P
it needs to be silver solderd m8 a few of the tuners on here do it but its not cheap
Old May 10, 2006 | 09:28 PM
markk's Avatar
markk
silver solder will crack, its too soft pal, you cannot weld an ally fitting to a steel rail.
the problem with the std rail is it has a small copper content that is used to seal the ends and the injector cups, this has to be removed before your STEEL fitting can be tigged on very nicely
Old May 10, 2006 | 09:54 PM
DAN P's Avatar
DAN P
ah i was wrong lol
Old May 10, 2006 | 10:01 PM
markk's Avatar
markk
Originally Posted by DAN P
ah i was wrong lol
too many people do it pal as well, looks to have taken but cracks off in a rough environment
Old May 14, 2006 | 08:36 AM
Mr C's Avatar
Mr C
ah i was wrong lol
Really, NOT what you want on a fuel rail, is a billet item recommended only then or does another cossie model have -6 fittings as std, ESCOS or ex rally car?
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
cossirob
Sep 16, 2015 07:39 PM
