Any one fitted concentric top mounts with coilovers ?
Old May 4, 2006 | 05:42 PM
Doug's Avatar
Doug
Default Any one fitted concentric top mounts with coilovers ?
As topic need help
Do uou still use any of the origional top hat or bearing from the origional suspension ?
Or is it a case of binnin the lot and offering your coilover with spring cap upto the new mount with the collar on the underside and the new nut on the top ?
Thank you please Doug .
Old May 4, 2006 | 05:54 PM
Doug's Avatar
Doug
Help ?
Old May 4, 2006 | 06:18 PM
Tony Ryan's Avatar
Tony Ryan
Theyre all different mate , what coilovers are you using ??
Old May 4, 2006 | 06:42 PM
Doug's Avatar
Doug
Avo's Tony
Old May 4, 2006 | 07:14 PM
Doug's Avatar
Doug
Think iv'e sorted it
Origional stuff below
Old May 4, 2006 | 08:17 PM
Tony Ryan's Avatar
Tony Ryan
Very pretty mate ! Bit overkill tho , normally 3 bolts holds em in ! Right idea tho , a top hat to centralise the strut and a nut in the top to stop it moving ,
Old May 4, 2006 | 08:21 PM
Tony Ryan's Avatar
Tony Ryan
This is how i fitted the WRC top mounts inside mine , had to space it up by 25mm to get the ride height back but sorted otherwise .
Old May 4, 2006 | 08:23 PM
Doug's Avatar
Doug
Rather be safe than sorry
Old May 4, 2006 | 08:41 PM
markk's Avatar
markk
was gonna say that could do with a few more bolts !
Old May 4, 2006 | 08:44 PM
Doug's Avatar
Doug
The tw@t ain't moving baby
Old May 4, 2006 | 08:46 PM
markk's Avatar
markk
Old May 8, 2006 | 11:35 AM
robrs2's Avatar
robrs2
Lots of bolts there Thought i was using to many with 4 bolts. Not got the coilovers fitted yet as i olny just got a set for Paul (NYRS spares). Pics are the standard 4x4 strut.
Old May 8, 2006 | 11:45 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Are they noisey?
Old May 8, 2006 | 12:29 PM
Markb_s1's Avatar
Markb_s1
sorry if i'm being stoopid, but aren't they eccentric top mounts rather than concentric? if not, what's the difference?
They look pretty much the same as the ones on my mk2 and i'm sure they're eccentric.
Old May 8, 2006 | 05:52 PM
robrs2's Avatar
robrs2
Mine are eccentric type.
The difference is that the hole for the strut is off centre with the eccentric ones and the concentric are in the centre as per the rubber doughnut.
Eccentric not usually used on road cars. You realy need to have fully adjustable front suspension to make good use of them i.e. adjustable tca's and compression struts.
Old Aug 7, 2006 | 11:19 AM
AdamB's Avatar
AdamB
sorry, but some of these pics aren't showing up, does anyone have any more pics?
matman
Sep 9, 2015 05:45 PM
yatta
Sep 1, 2015 11:28 AM
saph in dorset
Aug 14, 2015 10:10 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
