Whats the best steering wheel lock??
Old May 2, 2006 | 10:48 AM
RS Bowk's Avatar
RS Bowk
Default Whats the best steering wheel lock??
In your opinion whats the best steering wheel lock?
ie. stoplock etc and what type?
Im thinkin of buying one at the moment so am looking at my options and also where to buy from?
Thanks in advance
Mark
Old May 2, 2006 | 10:58 AM
rsnissan's Avatar
rsnissan
i think the disclock ones are the best with the back of them modded
pretty sure halfords sell them
Old May 2, 2006 | 11:19 AM
Oranoco's Avatar
Oranoco
As above DiscLock with the mod. But this is an as well as an alarm and immobiliser not instead of.
Old May 2, 2006 | 11:24 AM
gingeRS's Avatar
gingeRS
disklok is the only one to go for
havent had mine modded, but it could be done easliy i expect? just a case of weldign extra sheeting on the rear parts?
Old May 2, 2006 | 12:14 PM
RS Bowk's Avatar
RS Bowk
I have an alarm and 2 immobilisers also but am looking for something a little more
what do u lot think of the straight bar type stop lock?
and if disklok is the only 1 u recommend wheres is the best place ( price wise?) to get 1 from?
Cheers Mark
Old May 2, 2006 | 12:17 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Modified Disklok and alarm, immobiliser, tracker and a ground anchor.
Old May 2, 2006 | 12:18 PM
Cola's Avatar
Cola
Can I ask, what's the mod?
Old May 2, 2006 | 01:18 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Ditto - and who does the mod, any one with a welder or what?
Old May 2, 2006 | 01:20 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
You weld plate on the back to make it fit closer to the back of the wheel/steering wheel boss. Easy enough to do if you're ok with a welder
Old May 2, 2006 | 01:22 PM
Cola's Avatar
Cola
Oh yes, cos I reckon I'd be sh*t hot with one of them lol
Old May 2, 2006 | 01:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I plan to modify mine with some steel bars running up and down either side so it cant be prised off the s/wheel, but will still spin (bars will be shaped around the steering wheel, not completely flat! been told this is one way of getting around the lock!
And also around the lock area, weld some steel so it cant be bent apart
Sure their could be something done about the bottom hinge?
Also, does anyone elses lock feel like it wouldnt take much to bend the bar or snap it off from the top if you hold the lock and pull it upwards when it's engaged?
Old May 2, 2006 | 02:22 PM
AGAR-COSWORTH
Redumbdancy
Sounds good Dave, let me know how you get one with that - might give you another one to do aswell
Old May 2, 2006 | 02:34 PM
vroooom ptssssh
It Wasnt Me!
Will do, need to get my finger out, been meaning to do it for a while
Old May 2, 2006 | 03:54 PM
Dave Parker's Avatar
Dave Parker
someone got my mates off by removing the pin under the sticker on the front , the locking barrel just jumped out and released the arm
must have taken 30 secs .i put it back together in 2 mins with a new roll pin and it worked perfectly.
you can feel the pin hole through the sticker.. have had mine lightly welded over
Old May 2, 2006 | 10:34 PM
RS Bowk's Avatar
RS Bowk
BTTT
Old May 2, 2006 | 10:58 PM
RSBen's Avatar
RSBen
Cheers Mark
Straight bar type ones are a waste of space. 60 seconds with a hacksaw on the steering wheel, pull it apart and hey presto its off!
Get a Disklok from Halfords if you want to get ripped off or most shows for £40.
Old May 2, 2006 | 11:06 PM
vroooom ptssssh
It Wasnt Me!
cozzie_dave1, will be welding mine over too in that case
Old May 3, 2006 | 07:15 PM
Dave Parker
i`m relatively new on here what does BTTT mean on a post thanks
Old May 3, 2006 | 07:17 PM
RS Bowk's Avatar
RS Bowk
back to the top dave
so that ur post is on page 1
Old May 3, 2006 | 07:21 PM
Dave Parker
nice one will remember that thanks
Old May 4, 2006 | 11:06 PM
DanRs's Avatar
DanRs
bttt
Old May 4, 2006 | 11:11 PM
Sean_RS's Avatar
Sean_RS
I use a disclock... watched a programme with car theifs testing all different kinds, you have to remember that if somebody wants your car bad enough they'll get it, you just have to deter the best you can. The disclock took the longest time to remove and required the use of a power tool.
Old May 5, 2006 | 11:11 AM
Damo V's Avatar
Damo V
Disklok, Costcutter (50 quid) Or a show for a "second" 50 ish quid ... As above not unbreakable, but the best available.
Old May 5, 2006 | 11:38 AM
tonyk's Avatar
tonyk
I bought the new halfords own brand thatcham three approved lock and a disklok device for the handbrake to gear lever.
Old May 5, 2006 | 12:24 PM
RS500/364's Avatar
RS500/364
if you near surrey new one £49
Old May 5, 2006 | 02:19 PM
Dave Henshall's Avatar
Dave Henshall
im sure thay are 45 plus vat in costco, and thats for the silver one...?
if they are that intent to taking it, it will be gone on a low loader surely, as spend and hour grinding and cutting the discloc off,
good cat 1, 24 hr proactive tracker and a disclock and double lock or deadlock if you can the doors and thats really as far as you can go.... other than that... its insured aint it? just leave a note on the steering wheel... "if you can read this, please make sure you set fire to me afterwards" cos who wants a ragged trashed fooked car back, not me
Old May 5, 2006 | 05:31 PM
Damo V's Avatar
Damo V
duuuurrr I meant CostCo
Old May 5, 2006 | 05:51 PM
D7AKE's Avatar
D7AKE
uuuuuuummmmmmm
my disloc............
can i have it back when youve finished
Old May 5, 2006 | 07:29 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Thats basically the mod people talk about. You fill the area from those bars out to the edge of it with sheet metal.
Thats scary, but also re-assuring that you found that out.
Old May 6, 2006 | 12:56 AM
vroooom ptssssh
It Wasnt Me!
Rich_w, Sheet metal I thought would be easier to cut through, was thinking along the lines of something thicker, and aslong as their positioned as close to the centre of the wheel their wont be any way of it being prized off, although I do see your point about covering it all, might use thicker bars at the end like in the picture and cover the rest in sheet metal so it's not accesible!
Does anyone have a problem with the bar at the top feeling a bit flimsy, like it wouldnt takemuch to pull it off?
Old May 6, 2006 | 05:04 PM
Dave Parker
I dont know if everybody is aware but you can buy three different sizes, if you buy the right size disc lock for your wheel it should be harder to prise off , thats my way of thinking anyway
Old May 6, 2006 | 05:18 PM
Simon's Avatar
Simon
I think this is the mod everyone speaks of
Ps its not my pic it was someones of here about 2 years ago i just saved the pic so i could see how to mod mine (which i never got round too)
simon
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
