FITTED AP CLUTCH IN FRST WON'T GO IN GEAR HELP!!!!!!!!!!!!!!
Have just fitted a AP Stage one with Organic plate (not paddle) & now it just will not go in gear
clutch was replaced while engine was out of car & i thought it would be a good time to upgrade!,worked perfect with standard clutch had no probs up untill i fitted the AP
phone the company that sold me the clutch, they told me that i have to do NO modifactions as its a direct fit.
could it be to do with the quadrent in the peadle box?
any ideas or help appriciated
Press the clutch pedal down and get some to look under the bonnet to see have far the arm is moveing, this will tell you if its in the pedal, cable. area or its the clutch its self.
Dave
Dave
my mate had the same problem, we got it working by pressing the pedal down, holding the clutch arm in place on the top of the box and releasing the pedal, this can help it ratchet up. it worked ok but he kept loosing his pedal cos his quadrant was fooked. he ended up fitting the mk5 unit i think with no problems since.
Originally Posted by Doug
Stupid but fesable question the plate is in the right way ?
the only thing i have noticed with the new clutch is the "Fingers" on the cover are a lot flatter than on the standard item
could this be an issue with bearing not getting enough pressure???
only reason i can tink of as we have tried everything
Originally Posted by SassyRS
for a quick fix, take the cable off at the gearbox end & put a few sump washers on the the end of the outer cable where it sits on the gearbox.
still recon is to do with quadrent under pedal
mk 6 pedal is the best option, easy job on an escort turbo, but not sure if it fits straight into a fiesta, i think the pedal is a different shape.
read this mate, its a common prob with the naff adjuster had to do mine couple of days ago as had same prob
http://www.fiestaturbo.com/forums/about127412.html
quote by ap
When fitting the AP 4 paddle clutch, the company recommend you carry out this modification. The standard auto-adjust pedal's ratchet system can't take the additional pressure of the high-pressure clutch cover used with the paddle clutch, and they give up as mine did. Basically, your gears will become hard to engage, then your pedal will go to the floor and you'll have no clutch at all, so do this modification!
There was a Technical Service Bulletin for this problem.
In fact, on my AP fast road clutch I fitted it even advised to change the clutch pedal.
When I fitted the clutch the clutch worked, but I had to double declutch it to change gear properly - luckily I didn't have to drive it everyday.
A mate of mine on fiestaturbo.com listed the FINIS codes for the bits you'll need to convert your clutch pedal to manual adjustment.
http://www.fiestaturbo.com/forums/viewtopic.php?t=33200
Cheers,
Andy
Cheers,
Andy
track.focus'd
12-08-2015 05:53 PM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
