Anyone know about fitting condensor combi boilers? plumbers.
Old May 1, 2006 | 08:09 PM
Fiecos Dan's Avatar
Fiecos Dan
Default Anyone know about fitting condensor combi boilers? plumbers.
been fitting a new central heating system into my house this weekend.
I've fitted a C+M Minima HE 30 boiler.
but its come to the last connections on the boiler.
i have the C/H pressure releif valve, and a grey (about 25mm ID) flexi bit of pipe coming from the Siphon.
Where do these go, as reading the instructions, and they are not all that clear and its changes thro it.
i want to get it all running, then get a Corgi Plumber to check it, and set it up and sign it off. (got a couple of of plumbers willing to, as they know a mate)
Cheers Danny
Old May 1, 2006 | 08:13 PM
TIFF's Avatar
TIFF
Chasing Radders
The C/H pressure relief valve needs to go outside and be made so that it is pointing back onto the brick face. This is because if the pressure in the system gets too high it will release, and you dont want boiling hot water shooting across a path/garden ect
The other pipe is the condesing drain.
This needs to be either buried in an appropriate soak away in the ground (Will tell you in the fitting book) or be put into a drain with a sutable inline trap
hth
Old May 1, 2006 | 08:22 PM
Fiecos Dan's Avatar
Fiecos Dan
hth
It makes sense now,
Old May 1, 2006 | 08:25 PM
TIFF's Avatar
TIFF
Chasing Radders
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
