Torque settings
Old Apr 25, 2006 | 09:45 PM
Patto's Avatar
Patto
Default Torque settings
what are the torque settings for an erst head..? do you NEED to use a dial gauge or is a torque wrench ok..?
Old Apr 25, 2006 | 10:58 PM
ivorbiggun's Avatar
ivorbiggun
60 ftlbs (torque wrench), then a dab of tippex on each bolt cap and tighten a further 90 degrees and finally get the breaker bar out and another 90 degrees.
Make sure you're using a decent hex bit (snap on part No fam8e is
perfect)otherwise it's easy to damage/chew up the cap head.
Old Apr 25, 2006 | 11:15 PM
SafeChav's Avatar
SafeChav
Its recommended to work up to the torque in stages, doing it in one go won't make very even torques, the way i always do it (as per haynes) is
25, then 55, then 90 degrees then 90 degrees again. You dont need to use a dial gauge, if you use a torque wrench you can do it by eye easily.
ivorbiggun: they aren't cap head bolts.......13mm bolts....
Old Apr 25, 2006 | 11:34 PM
Patto's Avatar
Patto
steve.rst
Mar 15, 2016 08:01 AM
lime
Sep 25, 2015 06:56 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
