Brake light problem
right to cut long story short i have no brake lights. Replaced bulbs, fuses, and the brake switch behind the pedal. Nothing. I then took a live feed from battery to the pedal switch and i get brake lights
so i guess it must be the realy in the fuse box???? Woul you all agree? If so could anyone please tell me which relay it is becaus ei honestly havnt got a clue
Alright mate, i can have a look on the wiring diagrams for you tomorrow. Usually things like that are in with interior lighing feeds etc, have you looked at all the fuses in fusebox yet?
yes i replaced all fuses for new ones th eother day. I have not replaced all relays as at this point i dont think i need to.
I have all fogs rear lights and bumper lights and indicators working to the rear.
If its a fuse you will have other things that don't work, there wont be a fuse just for the brake light wiring. More than likely tapped off one of the side light circuits.
I'll be able to tell you tomorrow
right i did a test wire from the live bat terminal direct to the brake light switch. It sent power to the lights and the work
I tested the fuse box and theres power there. I have therefor come to the conclusion that there has been a break in the circuit from the fuse box to the brake switch
what i have done temporarya s i nee to get it motd is run a piece of wire from the brake light pedal switch to the yellow ignition wire
it works
it works
van_dogg_pavvy
Mar 3, 2016 09:30 AM
