How much boost shall i give her!!
Old Apr 23, 2006 | 01:22 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default How much boost shall i give her!!
Just got me S2 back on the road and since i rebuilt it she has lost lots of low and mid range torque.
DIY ported head, inlet and exh manifold (matched ports)
piper 285 T2 cam
vernia pully
S/Steel valves
Grp A felpro gasket
Cosworth forged pistons approx 7.5:1 CR
Rebored to 81.50mm
Lightened and balanced crank, flywheel and clutch cover
hi presure oil pump
DIY boost activated 5th injector @12psi
Holding 20psi
Stage 2 T3 turbo -31
pace double capacity intercooler
lagged turbo / manifold
usuall extras, chip, filter, exhaust, swirl pot etc.
what boost do you think i should run and also being low comp and a laggy cam is it worth putting the std cam back in to regain some low down grunt
cheers for any help
Bri
Old Apr 23, 2006 | 01:25 PM
notSteveS2's Avatar
notSteveS2
no more than 22 psi it think if u got standard rods!
wot rods matey?
Old Apr 23, 2006 | 01:31 PM
*Bri.4.b.Cos*
std rods, before rebuild done a compression test and she was 14bar apart from pot 3 with half a piston lol. After rebuid with me low comp pistons (approx 7.5:1) done a compression test and got 10 bar across the lot. Will this lower in cylinder pressure allow me to run more boost?
Old Apr 23, 2006 | 01:39 PM
notSteveS2's Avatar
notSteveS2
yes low compression engines allow u to run more boost mate other wise they r pointless.....
dependin on how gd ur management is set u can run alot of boost...
but too much and ul bend a rod...
aslong as manaegement , be it efi or mfi, is et up well id say u cud run between 20 - 25psi!
but dont hold me to that... others with greater knowledge than me may say otherwise!
Old Apr 23, 2006 | 01:44 PM
*Bri.4.b.Cos*
Old Apr 23, 2006 | 01:47 PM
notSteveS2's Avatar
notSteveS2
as i say mate.... its vital u make sure u got fuelin system capable of this boost... or ul run lean and then...
BANG!....
not gd.
Old Apr 23, 2006 | 02:04 PM
shane's Avatar
shane
as above get it setup first,but should be good for 25psi with that Comp Ratio,but get fuelin done otherwise cud end up melting stuff!
Old Apr 23, 2006 | 03:45 PM
Southsidecreations's Avatar
Southsidecreations
Default question mate?
Where did u get the switch for the diy boost activated 5th injector?
Old Apr 23, 2006 | 04:39 PM
addiction's Avatar
addiction
also you say that you have a Pace double capacity intercooler!!
i hope you've got an act gauge fitted as that interwarmer is not going to like anything above 16 psi without running very high act's!!
i also take it that you've run the rebuilt engine in for at least 1000 miles,although personally i'd run it in for 1500 miles!!
Old Apr 23, 2006 | 04:41 PM
notSteveS2's Avatar
notSteveS2
get a GRS!!!!!!!!!
Old Apr 23, 2006 | 04:56 PM
DazC's Avatar
DazC
On that head gasket, you're probably already over it's limit!!!
Boost pressure depends on what your fueling is capable of doing and ignition advance/retard.
Old Apr 23, 2006 | 05:06 PM
notSteveS2's Avatar
notSteveS2
wud use standard ford head gasket .....
is that not strong enuff?
Old Apr 23, 2006 | 05:27 PM
DazC's Avatar
DazC
The standard Ford one is probably the best out there. The Felpro is a normally aspirated head gasket deisnged for the 1.9 american engine with no turbo on it. They usually blow between 2 cylinders.
Old Apr 23, 2006 | 05:37 PM
notSteveS2's Avatar
notSteveS2
yea i thought so matey...
i always use standard 1... never 1ce blown a head gasket!
Old Apr 23, 2006 | 06:56 PM
*Bri.4.b.Cos*
ran her in for 1500 miles very low boost then 1500 - 2000 at 16 psi taking her easy ish and she now has 3000 miles on her. I just got her back on the road to sell her but i forgot how much i love the RAWNESS of it compared to me saph and now don't want to let her go
Old Apr 23, 2006 | 07:07 PM
*Bri.4.b.Cos*
Default Re: question mate?
Its a adjustable pressure switch betwean 0.8 and 6 bar off the Scully system on a road tanker. £70 each but i liberated them from our stores dept untill they ran out
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
