had me car on rollers today
Old Apr 19, 2006 | 09:14 PM
b14dave's Avatar
b14dave
Default had me car on rollers today
its got greens,3bar 4*4 intercooler,t34 and only produced 290bhp at 21psi why? what do yours make with this spec ?
Old Apr 19, 2006 | 09:21 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I'd expect slightly above 300, maybe 310/320
What rolling road was it ? Maybe it was reading low.
Old Apr 19, 2006 | 09:51 PM
b14dave's Avatar
b14dave
track and road.it had 275lb of torque
Old Apr 19, 2006 | 11:47 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
that dont sound right ive got stg 2 conversion on mine chip light greens standard t3 19 psi and that was 296 bhp 309 torque ! prob something wrong with the rolling road
Old Apr 20, 2006 | 02:36 AM
Staffi's Avatar
Staffi
Sounds like a set up, and live map needed
Old Apr 20, 2006 | 08:47 AM
b14dave's Avatar
b14dave
no miss fire said was running nice maybe
Old Apr 20, 2006 | 10:24 AM
JamesH's Avatar
JamesH
My old one made over 330bhp @ 22 psi and 356bhp@ 26psi!
Has the engine been rebuilt/how many miles?
Old Apr 20, 2006 | 12:01 PM
xr4i's Avatar
xr4i
My 3dr has same spec only running 13psi due to ecu playing up,was on the rollers lastweek and put out 307bhp and 296lbft.
Old Apr 20, 2006 | 04:05 PM
R4N SS's Avatar
R4N SS
my stg3 setup made around 340-350 @ 28psi
Old Apr 20, 2006 | 04:31 PM
KSA-Cossie's Avatar
KSA-Cossie
That's a bit on the low side m8.
Old Apr 20, 2006 | 05:49 PM
cos47's Avatar
cos47
Mine made 349BHP and 355ft/lb @ 1.6 bar (23.5psi)(Greens,T34and 500 cooler) i would get a set-up mate
Old Apr 20, 2006 | 06:48 PM
nice_head's Avatar
nice_head
mines got the spec as you and i got 329bhp
Old Apr 20, 2006 | 08:07 PM
costina's Avatar
costina
Live long and prosper!!
same spec 329bhp 328lbft holding 24 psi charge air 45oC and overfuelling
Old Apr 20, 2006 | 08:36 PM
b14dave's Avatar
b14dave
yea must be due for a rebuild as i do have a bit of cylinder leakage and blow by what checks can i do, i know to do compression test what pressure should i be looking at b4 rebuilding it
Old Apr 20, 2006 | 08:54 PM
Staffi's Avatar
Staffi
Doesn`t mean a rebuild at all mate yet just get someone to check it over and get it live mapped and take it from there your in Essex, why not give Mark a call at MA DEVELOPMENTS
Old Apr 20, 2006 | 09:03 PM
b14dave's Avatar
b14dave
any1 know of any1 they recomend in essex area
Old Apr 20, 2006 | 09:31 PM
Staffi's Avatar
Staffi
Nowhere near Essex i know, but Karl Norris......NMS is just awesome, im sure alot of people will second that but as i said, its a bit of a travel, but youre car will be transformed mine was........IS
Old Apr 21, 2006 | 09:20 PM
nice_head's Avatar
nice_head
Engine Advantages
Old Apr 21, 2006 | 10:08 PM
b14dave's Avatar
b14dave
it is only running at 21psi and holding 20.5
Old Apr 22, 2006 | 07:45 AM
KSA-Cossie's Avatar
KSA-Cossie
Should still have more power at that boost m8,EA should get you sorted out.
Old May 10, 2006 | 01:59 AM
tybrown's Avatar
tybrown
Im new.. i live in australia,
with your HP readings. is it at the fly wheel or the rear wheels??
im running 2wd sapphire with ahmed 400bhp chip. t34 turbo standard cooler and 23psi. what power should i expect at the wheels??? and with the ahmed chip how much boost do you think i can run 28? 30psi?? when i get a larger intercooler of course?
Old May 10, 2006 | 07:25 AM
p_jay78's Avatar
p_jay78
If you fancy a little trip around the m25 Power Engineering in Uxbridge are really good....
just my 2 pence worth....
Old May 10, 2006 | 11:13 AM
rapidcossie's Avatar
rapidcossie
is it ATW??
mine made 290 ATW in this spec
Old May 10, 2006 | 10:38 PM
GUZZLER's Avatar
GUZZLER
bring it to Powers
Old May 11, 2006 | 05:02 PM
bezo's Avatar
bezo
powered by K26
seems very down on power, mines a similar spec and mine did 311whp@6050rpm running 18psi
Old May 11, 2006 | 05:04 PM
rapidcossie
sorry my car ran 265 at wheels with the 4x4 cooler, so probs about 300 horse mate
Old May 11, 2006 | 08:23 PM
ark1's Avatar
ark1
Mine is running at 333bhp with 376lb torque.
I have greens, 3 bar, T3 turbo, 500 intercooler, about 22 psi.
track.focus'd
Aug 12, 2015 05:53 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
yawiejon
15
Aug 9, 2015 06:36 PM
xr_craig
Aug 7, 2015 06:00 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
