help fiesta mk3 1.1 hcs to 2.0 litre mondeo zetec lump
Old Apr 18, 2006 | 03:32 AM
davies84uk's Avatar
davies84uk
Default help fiesta mk3 1.1 hcs to 2.0 litre mondeo zetec lump
hi i currently own i 1.1 hcs mk3 fiesta but i'm thinking of puttin a 2.0litre zetec lump in it .i would lk to know how big a job this is and wot additonal parts i would need i.e driveshafts ,ecu, wireingloom etc .also if there may be any problems i might come across during the swap .any help is greatly appretiated thanks.
Old Apr 18, 2006 | 04:07 AM
davies84uk's Avatar
davies84uk
since postin i been havin a look round on the net and it seems a 1.6 lump would be easy but from wot car and would it just bout straight in
Old Apr 18, 2006 | 06:17 AM
BRAMMER's Avatar
BRAMMER
If you are thinking of an upgrade go for the 2.0 block just because of the potential power increase,
You will need to take the engine, loom/ecu and sensors and mountings then attach a erst gearbox and a decent clutch, a set of cvh drive shafts and a few bits and bobs.
I'm not to clued up on the n/a conversion but i'm sure there are different ecu's, your best getting advice from some of the other users.
You should see 150bhp out of a n/a engine and a fair amount of torque
Old Apr 20, 2006 | 06:55 PM
ru55e11's Avatar
ru55e11
what about a 1600 cvh non turbo? , thats what i might do, i was under the impression that you didnt need to spend too much to get it sorted?
Old Apr 20, 2006 | 09:20 PM
davies84uk's Avatar
davies84uk
well i decided i'm guna put a 1.6 xr2 engine in for nw and mayby go for the zetec later on .its seems alot easyier to fit the 1.6cvh than the zetec and cheaper .
Old Apr 22, 2006 | 12:44 PM
PeterD's Avatar
PeterD
Speak to xr stu mate, hes done the 1800 convo i think and im sure hes about to do a 2.0 as well, you could also speak to jamsport or maybe try vulcan or burton power, im sure jamsport did a 2ltrs xr2 a while back.
Or you just fuck it and get an rs2000 jobbie in there
Old Apr 22, 2006 | 08:43 PM
BRAMMER's Avatar
BRAMMER
If your going cvh then get a full cvh turbo conversion there is the same amount of work and the cost is not a great deal more and the tuning aspect is massive.
andyrs1600i
Yesterday 03:21 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Bosch
Aug 4, 2015 05:14 PM
