help fiesta mk3 1.1 hcs to 2.0 litre mondeo zetec lump
hi i currently own i 1.1 hcs mk3 fiesta but i'm thinking of puttin a 2.0litre zetec lump in it .i would lk to know how big a job this is and wot additonal parts i would need i.e driveshafts ,ecu, wireingloom etc .also if there may be any problems i might come across during the swap .any help is greatly appretiated thanks.
If you are thinking of an upgrade go for the 2.0 block just because of the potential power increase,
You will need to take the engine, loom/ecu and sensors and mountings then attach a erst gearbox and a decent clutch, a set of cvh drive shafts and a few bits and bobs.
I'm not to clued up on the n/a conversion but i'm sure there are different ecu's, your best getting advice from some of the other users.
You should see 150bhp out of a n/a engine and a fair amount of torque
Speak to xr stu mate, hes done the 1800 convo i think and im sure hes about to do a 2.0 as well, you could also speak to jamsport or maybe try vulcan or burton power, im sure jamsport did a 2ltrs xr2 a while back.
Or you just fuck it and get an rs2000 jobbie in there
JoeyBoyden
04-01-2024 02:36 PM
