cossie engine rebuilds
Old Apr 17, 2006 | 12:11 AM
b14dave's Avatar
b14dave
Default cossie engine rebuilds
been ruuning stge3 and my engines done bout 30000mls since rebuild had head gasket and stuff since but it now drinks,burns alot of oil wonder if its due a freshen up,
Old Apr 17, 2006 | 12:25 AM
rapidcossie's Avatar
rapidcossie
shouldbe doing this so soon after a rebuild.
30 k isnt much
Old Apr 17, 2006 | 12:41 AM
b14dave's Avatar
b14dave
you think so does get hammerd though,well it got done in 1999 and it had new clocks in 98 and its only got 45000ml on clock maybe 40000ml then
Old Apr 17, 2006 | 10:14 AM
costina's Avatar
costina
Live long and prosper!!
Check your breathers make sure there not blocked
When it first comes on boost do you get a puff of blue out back?
I had same prob the turbo was leaking oil into cooler
Had turbo recon now its ok mines done 102k all on lights greens
What oil are u using? my mate ran his 4 years on 0/40 mobil 1 he used a lot also
Old Apr 17, 2006 | 11:18 AM
b14dave's Avatar
b14dave
i got one of them bailey breather systems as it used to blow loadsa oil out the engine breather and i mean loads in a mile of driving of the lights flat out it would chuck a cup full of oil into a pot,ive tried all different oils mobil 1,castrol, fords,it had a new t34 not to long ago and has probaly only done 2000ml
Old Apr 17, 2006 | 11:29 AM
costina's Avatar
costina
Have you oil in intake manifold ?
sounds to me u have excessive crank pressure.
How did u fix the oil getting into pot? is the return to sump pipe blocked or restricted?
Old Apr 17, 2006 | 11:57 AM
b14dave's Avatar
b14dave
fixed the oil by fitting bailey breather system thats only a year old it returns it to sump,im thinking crancase pressure but how you sort it new rings?when to tommy field bout 2 year ago and they said i had 8%cylinder leakage and was coming out threw crancase breather.
Old Apr 17, 2006 | 12:13 PM
costina's Avatar
costina
That would b the problem the rings
This just maybe down to havin a hard life(but fun!!!)
Do a compression check then decide
Old Apr 17, 2006 | 08:27 PM
b14dave's Avatar
b14dave
think they was about no.1 cylinder 140psi
no.2 cylinder 120 psi
no.3+4 was 130psi
Oct 9, 2015 07:38 PM
Gadget
Aug 26, 2015 01:02 AM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
