s2 anti-roll bar removal
Old Apr 15, 2006 | 02:42 PM
RSandy's Avatar
RSandy
Default s2 anti-roll bar removal
ok, iv taken the anti roll bar off with the bottom arms stil attached.
iv come to undo the 24mm bolts where the bar passes thru the bottom arm, and they are just stuck, really stuck. iv tried an air gun with a small compressor, no joy there. iv tried a torque wrench with me hangin off it. no joy
iv been told 1 end of the anti roll bar will or may have a left handed thread. does any1 know which side is this left handed thread?? and any general ideas for removing these damn bolts wud also be great
Old Apr 15, 2006 | 04:19 PM
Moondust_crust's Avatar
Moondust_crust
drivers side is left handed thread mate so undo it the other way, i also did what you did and took it off in one piece, tip is to get your mate to stand on one end while you get a blowtorch and a large 24mm spanner and a scaf bar on the other, it will give in the end , other wise just get angry with it. worked for me! cheers mark.
Old Apr 15, 2006 | 04:25 PM
gambit's Avatar
gambit
Default anti roll bar
yep drivers side mate, i managed to get mine of with a big bar and alot of man power.
Old Apr 15, 2006 | 08:16 PM
mercury grey minter's Avatar
mercury grey minter
Yep.breaker bar with a metre long scaff bar over it .
Old Apr 15, 2006 | 11:24 PM
HORNETS7's Avatar
HORNETS7
but they key to it is deffinatley a left hand thread u need turn it clock wise to remove it!
Old Apr 16, 2006 | 02:56 PM
Ben26's Avatar
Ben26
Defo a left hand thread mate , i had the same problem a couple of weeks ago. hope fully u have not done it up to tight and u will be able to get it off
Old Apr 16, 2006 | 04:18 PM
SafeChav's Avatar
SafeChav
I doubt u will ever get that off if the rollbar isn't on the car
Tighter than a camels ass in a sandstorm
Old Apr 16, 2006 | 04:25 PM
Moondust_crust
[quote="safechav"]I doubt u will ever get that off if the rollbar isn't on the car
got no faith!, do it my way and it will come off!
Old Apr 17, 2006 | 09:23 AM
Ben26's Avatar
Ben26
Old Apr 17, 2006 | 10:30 AM
SafeChav's Avatar
SafeChav
Old Apr 17, 2006 | 08:57 PM
Drjones's Avatar
Drjones
i got mine off!!! oxy-set!!!!!!!!!
Where can i but new bolts tho???
Old Apr 17, 2006 | 09:06 PM
Little_Hoss's Avatar
Little_Hoss
[quote="Drjones"]i got mine off!!! oxy-set!!!!!!!!!
aye after twatting it with hammers etc before realising the left hand thread
Old Apr 17, 2006 | 09:10 PM
Drjones's Avatar
Drjones
[quote="Little_Hoss"]
Very ture
Old Apr 17, 2006 | 09:25 PM
Moondust_crust
Drjones
ford still do the nuts to go on the end mate.
Old Apr 17, 2006 | 10:02 PM
Drjones's Avatar
Drjones
sound
Old Apr 19, 2006 | 07:00 PM
bassy_g's Avatar
bassy_g
i used the powerbar with a very large trolley jack handle attached with it still on the car
Old Apr 21, 2006 | 05:24 PM
ivorbiggun's Avatar
ivorbiggun
Bunch of girls I do mine with me bare hands/but then, I am HARD
Old Apr 21, 2006 | 10:23 PM
SafeChav's Avatar
SafeChav
Old Apr 21, 2006 | 11:38 PM
RSandy's Avatar
RSandy
little update as it seems the thread has been ful of advice
i stil cnt get the fooker to budge, neither side, impact wrench says no, breaker bar says no, several people holding whilst several others lean on breaker bar stil says no. lookin at maybe investing in a large piece of scaffolding
either that, or iv already bought new bottom arms, so mite just buy a replacement ARB and give up like the wimp me, and my mates, apparently are
Old Apr 21, 2006 | 11:40 PM
SafeChav's Avatar
SafeChav
Why dont u just bolt it back up on the brackets (4 bolts) and then undo it? I've undone loads of these on the car with a 2 foot (prob not even that) torque wrench
Old Apr 21, 2006 | 11:45 PM
RSandy's Avatar
RSandy
kind of stripped the car absolutely bare, so to bolt it back up wud mean bolting a fair wedge of other stuff bk up lol
also iv found out im still on a lower spec 22mm ARB, and the rs turbo runs a 24mm item, so the polybushes iv bought wil need the larger diameter ARB to b used, so i may aswel go buy the thicker 1, join it to my brand new bottom arms, then dump the old stuff in 1 go.
altho sayin that, its pissed me off so much i dnt want to admit defeat, we drank a whooooooooooooooole lot of beer and got absolutely nowhere, infact my m8 has been in bed with a bad back for a couple of days as a result lol lol
Old Apr 21, 2006 | 11:48 PM
SafeChav's Avatar
SafeChav
They can be a right slag to do. Like drive shaft nuts bit of a pet hate, first thing i do now before anything is get the torque wrench out with the car on the road and see if the bastard nut wants to play ball or not
You car a Genuine RS then?
Old Apr 21, 2006 | 11:50 PM
RSandy's Avatar
RSandy
nah, mines built from a 1.3 popular shell
had evrything else changed to rs spec, except for anti roll bar set up, didnt realise there was a difference to be quite honest
my hub nuts were fine wen using the impact wrench, but these arb bolts must have been dun up waaaaaaaaaaaaay too tight, by me aswel apparently accordin to my mate who helped me take it off last time, oops
Old Apr 21, 2006 | 11:53 PM
SafeChav's Avatar
SafeChav
Im puttin a S1 roll bar on my cabby, no reverse thread so i can enjoy the simplicity of removal with stainless nuts
Get a new roll bar then, ebay.......be cheap enough
DixieTheKid
11
Jun 6, 2020 11:20 AM
cossie330
Oct 7, 2015 08:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Fudgey
Sep 17, 2015 01:06 PM
hopper350
Sep 4, 2015 12:53 AM
