Zetec Turbo fuelling questions...
Old Apr 13, 2006 | 09:47 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default Zetec Turbo fuelling questions...
Ok - so as my stockpile of parts grows and grows i've come to the fuelling issue...
Ideally looking for a figure of around 350bhp i can't decide whether to go for 803 Greens and accept a slightly lower figure (don't want to max out the duty cycle) - or whether to go to Light Blues and risk a lumpier idle.
That's all assuming i use Bosch injectors - i've heard that Siemens etc have better spray patterns etc. - so any recommendations would be appreciated.
Also - fitting into a Series 2 shell - i think i'm right in saying that the fuel tank thats still on there is not suitable as it doesn't have a fuel return with it being from an MFi car...
So... Could i fit an XR3i fuel tank (i.e set up for fuel injection return) - or would it be easier to junk it and just fit an alloy cell in the back?
Which brings the next question - what fuel pump?
Also - what fuel bits do i need in the form of swirl pots etc?
Any advice appreciated.
Old Apr 14, 2006 | 02:50 AM
AndyRST's Avatar
AndyRST
Default Re: Zetec Turbo fuelling questions...
The 2 of the big power T34 CVH's on here are using greys i think. At a guess greens defo arent up to the job.
Wont the injector size depend on what turbo and what boost you need to porduce to make the power you want ?
Old Apr 14, 2006 | 08:58 AM
Big Will_'s Avatar
Big Will_
I'm looking at a GT28RS with around 22psi mate
Old Apr 14, 2006 | 09:12 AM
GARETH T's Avatar
GARETH T
buy the injectors what suit your ecu
Old Apr 14, 2006 | 09:14 AM
Big Will_'s Avatar
Big Will_
Gareth - i've got OMEX 500 that's mapped for a similar engine on 803s so would almost plug and play...
But i've got a mate offering me Motec quite cheap - and its a much better ECU - so i'm able to go with whatever really
Old Apr 14, 2006 | 09:16 AM
GARETH T's Avatar
GARETH T
ahh cool,,,, buy some nice big injectors then
Old Apr 14, 2006 | 09:23 AM
Big Will_'s Avatar
Big Will_
I've got a set of Focus RS ones that i've been told will flow 400... Might just hang onto those thinking about it...
Now - the tank question?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
