Transverse YB
Now then ...
I heard some time ago that this was (basically) do-able with an MTX75, retaining the original-ish front end of the car. Can anyone shed any light? I don't like being wrong, and I'm sure this came off a respected source...
Cheers!
Steve
Cheers!
Steve
Guest
Posts: n/a
Yes its been done, I think the Fiesta that AVA did is the most common one people know about.
Dont know to many details off the top of my head, but it seemed a fuck load of hard work for not alot of advantage over something like a Zetec turbo etc.
No worries
Somebody's just said to me that you have to space-frame the whole front end, which I don't remember being necessary... perfectly happy to admit when I'm wrong lol... I just don't think I am...
I remember seeing (a looong time ago) a grasstrack mini clubman with a transverse Cosworth engine in it
just thought I would share that useless info with you all
dont have to space frame it but drivers side inner wing needs totally redesigned. to fit round the elbow on the water pump etc, also the turbo has to b mounted upside down for clearance at the bulkhead, so i'm assuming you would need a manifold made to allow this.
it would be easier to spave frame it tbh
as look at the engine mounts one would be where the rad is and the other bulkhead
as said turbo goes upside down, then you have the grief of water pipes, boost pipes etc
a lot of work for gains i carnt see why and would just do it normal and weld a floor pan in
there was a mk5 escort that had been done years ago aswell, also the ka with evo running gear
liamT74
Sep 23, 2015 10:24 PM
landaqmabba
Aug 20, 2012 07:07 PM
Chip
Sep 30, 2009 11:53 AM
Dan1980_4x4
Dec 9, 2004 07:18 PM
