cv boot clips rear shafts(cable ties ???)
hi people i got a pair of rear driveshafts for me 2wd saff but i wanted to paint them up and give them a good clean (my mate has a steamcleaner parts washer thingy) but can you buy the clips to hold the cv boots on as the old ones have no way of being refitted
Originally Posted by mercury grey minter
You can get the cv boot retaining clips from FORD but you need a special tool to fit them.Most people just use cable ties.
Just make sure the CV is clean where the boot locates or it can slip off, especially with cable ties. And you dont need a special tool for the proper clips, just some pincer pliers
Cable ties are fine and not an MOT failure. I personally use 2 cable ties next to each nice and tight and no probs. In my opinion better than the metal clips. My girlfriend's car has had the proper metal clips come off before.
there is a special tool for crimping them ,i brought one and if you want to come to devon you can borrow it
,it crimps and pushes at the same time and has a hole so you can actually torque them up with a torque wrench.
Cable ties are pants and with a lowered car the shafts are at a nasty angle and the boots fall off.
,it crimps and pushes at the same time and has a hole so you can actually torque them up with a torque wrench.Cable ties are pants and with a lowered car the shafts are at a nasty angle and the boots fall off.
Just use jubilee clips if you have enough clearance.
That's what i use and theyve lasted years. It was originally the mechanics at the main dealer who gave me this kinda obvious tip years ago
3dr cossie
21
Nov 20, 2015 05:00 PM
rog
Aug 31, 2015 04:18 PM
