rc cars
rc cars
anybody got any rc cars,heres pics of my 2,the petrol car is a serpent impact with a kyosho gs11 engine in it but the engine is knackered so just waiting for a kyosho gs12 engine to turn up that i got off ebay the electric car is a yokomo yr-4 II,it has got carbon fibre chassis,carbon suspension brackets front and back,carbon fibre diff top covers and carbon fibre top chassis/impact absorber,its also got a sports motor aswell and the electronic spped controller has even got abs lol
Here's mine, nothing fancy. Have added a full ballrace kit and 18T motor.
My brother has a good collection including several cars and a helicopter which is proving really hard to fly
i would love a decent nitro car but just havnt got the money really but will hopefully get 1 sometime next year,i wouldnt mind fitting a bit bigger engine into it but its hardly got any space round the engine so wouldnt be worth the trouble,100mph thats going to be naughty,the motor in the electric car is a 12turn double wind,it can be adjusted for spped or endurance,im going to find some drift tyres for it and hav a play around with it out the front of my house
Originally Posted by miller3
Check this out' Click the link for the record.
http://www.racers-haven.com/world_record_run.php
Heres mine, It s Schumacher SST Sport, full carbon chassis, cost me a bomb back in the day, used to race it before I came to swansea, I have races it on the touring on tarmac, but its set for rallying which was the last thing I raced in at Tiverton.
With a few aerodynamic mods, gearing and a more powerful battery.. will see 100mph quite easily.. and it will get there faster than a nitro car easily
Also should be good for 13-15second 1/4 passes
Nick still about.. Not seen you on Schueee in a while lol
CheeRS... not selling it though only just spent Ł250 on electrics
Basically
Surikarn Features:
39 Tooth Pulley (Ball Differential)
39 Tooth Pulley (One-way)
Aluminum Diff Cup Joint Set
Diff Cup Joint Adapter (2pcs)
Heavy Duty Front Shock Tower 3.5mm
Heavy Duty Rear Shock Tower 3.5mm
Front Bulkhead Set (blue)
Rear Bulkhead Set (blue)
Motor Mount (blue)
Middle Block R (blue)
Upper Bulkhead Set (blue)
Bearing Holder (blue)
Pivot Block FR (blue)
Pivot Block RF (blue)
Steering Arm Set (blue)
One-way Holder (blue)
Spur Gear Hub (blue)
Belt Tensioner Mount (blue)
Shock End Ball (blue/4pcs)
Cylinder Upper Cap (blue/2pcs)
Cylinder Lower Cap (blue/2pcs)
Titanium Turnbuckle M3x24mm (blue/2pcs)
Titanium Turnbuckle M3x34mm (blue/2pcs)
Aluminum Washer 3x6x0.75mm (blue/10pcs)
Aluminum Washer 3x6x2.0mm (blue/10pcs)
Servo Saver Set (blue)
Wheel Nut M4 (blue/5pcs)
Pivot Block (Front or Rear/2.5 Degrees/Aluminum/blue)
Pivot Block (Front or Rear/3.0 Degrees/Aluminum/blue)
Ball Set For Sway Bar (blue/4pcs)
Solid Axle (1 Piece Type/blue)
Aluminum Servo Mount Set (blue)
Aluminum Spring Mount (blue/4pcs)
44mm Aluminum Universal Drive Shaft (blue/1pc) ++
Novak GTB Brushless/Brushed ESC
Novak 3.5 Velociti brushless motor
Team Orion 7.4v 4800 li-po
Futaba 3050 servo (nothing special)
Sanwa gemini 2 radio gear
Titanium front drive shafts
cs-22 tyres
Surikarn Features:
Motor Mount (blue)
cs-22 tyres
Originally Posted by nickymi2
Basically
Surikarn Features:
Motor Mount (blue)
cs-22 tyres
Surikarn Features:
Motor Mount (blue)
cs-22 tyres
With rubber tyres ay Nick
FOAMS ROCK.................
i keep looking at the classic tamiyas on ebay,would love a midnight pumpkin and the lunch box aswell as i always wanted 1 when i was younger and there quite cheap off of ebay aswell just got to wait to get it from hong kong or something
Few of mine
Modified Schumacher menace GTR running a .28 engine should be good for 100mph
Plus that looks like a complete piece of shit! nice shell!
It stands a far better chance than your fusion..
+++ check out the custom gearing from the engine.. + the extra torque of the .28 to pull it through the lower overall ratio in each gear.. it will easily see 100 on a long enough straight
i have a Xtm xt2 for the 1/8 scale off roading, and a 1/10 Cen gx 01 for the road with a 2 speed gear kit and soon to be a 24.7 engine off the xtm for fun.
Originally Posted by RobS
My Cen truck, 5.5hp
my savage
AE MGT
got 2 cars aswell, one petrol one elec, trucks more fun tbh
my savage
AE MGT
So then guys, you've made me want another one now What would you suggest?? Nitro is just too much buggering about, so probably electric, would like a buggy/truck for off road, and i want it to go like fook
Suggestions please
PassionFORD Member
HPI R40 Currently running a Vega V12, CVEC Pipe and hopups which I cant be bothered to list right now since theres too many lol. I also have a novarossi engine with it and two other pipes. Shell is a Pennzoil Skyline GT-R. Sitting quite low there
Miller, havent seen your car in a long time. Hows it going?
My Cen truck, 5.5hp
my savage
AE MGT
my savage
AE MGT
Suggestions please
http://www.teamlosi.com/Products/Def...rodID=LOSA0015
http://www.teamnovak.com/products/br...tem/index.html (6.5 system)
http://www.apexmodels.co.uk/product-...ories&id=11058
depending on gearing that will be good for 60mph
STOP!... Carry on
Originally Posted by xr2i-carl
mine, got an 1995 dtm alfa somewhere i had from new!!
maight get it out soon now!!
