SHOULD I CHANGE THE OIL PUMP ?
Old Apr 12, 2006 | 02:17 PM
tosh's Avatar
tosh
Default SHOULD I CHANGE THE OIL PUMP ?
Hi, can anyone tell me at what stage of tune should you uprate the oil pump on a cosworth, it had a full rebuild to a standard stage one, 3 years ago and has done little mileage since then but since then I have gone to a stage 2 about 300 to 320ish BHP,
so I was wondering if it is worth uprating the pump, as I will be taking the sump of this weekend to fix an oil leak anyway. Cheers!
Old Apr 14, 2006 | 06:15 PM
tosh's Avatar
tosh
NO replys yet I suppose all the experts are at the ring "lucky feckers"
seious though if someone can answer the ubove, as I need to order one soon so I can get started,
CHEERS in advance
Old Apr 14, 2006 | 06:23 PM
rapidcossie's Avatar
rapidcossie
there is a new updated 4x4 pump available from cosworth.
stick one in if you have it all out anyway..
think its about 140 quid tho
Old Apr 14, 2006 | 06:40 PM
SafeChav's Avatar
SafeChav
Pump change can never go a miss and uprated ones can only be good if anything......
Old Apr 14, 2006 | 07:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
if you have good oil pressure and flow, and are suffering from no problems, then i don't see any benefits TBH.especially at just stage 3 power, however a new part is always a good thing
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
