solid lifters in a 1600cvh turbo
what exact advantage would having solid lifters out of the escort 1600i give over the normal ones in a 1600cvh turbo engine?
few people have sugested that i do it, just wandering what advantage it would give over the std ones as to if it is worth doing or not.
thanks
James
thanks
James
Youd need a cam to suit the solid lifters too, cant use solids on any old cam.
I guess they rev more freely than hydraulic ones and wont 'pump' at high revs. I suppose it depends on the spec of the rest of the engine and turbo as to whether you will need to rev it hard enough to need solid lifters?
JK12
33
Apr 26, 2021 12:09 PM
