Changing S1 Gearbox Oil Seals.....is it DIY ??
Old Apr 10, 2006 | 10:10 PM
MichaelG's Avatar
MichaelG
Default Changing S1 Gearbox Oil Seals.....is it DIY ??
Gearbox is out of my Series 1, and while its out i will be cleaning it up etc and would like to replace the old oil seals (4 i believe)
Question is, is this a DIY job ? Has anyone done it themselves and whats involved ?
Just want to get an idea before i get set on doing it and cant lol
Cheers in advance
Michael
_________________
Old Apr 11, 2006 | 06:48 PM
biglee's Avatar
biglee
Audio specialist
drive shaft seals are a piss easy, just a case of poping the old ones out with a screwdriver and tapping the new ones in with a suitable sized socket (same size as the metal part of he seal), dont know on the others tho
Old Apr 11, 2006 | 09:38 PM
SafeChav's Avatar
SafeChav
The hardest bit about this is getting CV's out IMO. As biglee said u pry the old ones out and gently tap in the new ones. I'm not sure about 4 though???? 1 on each driveshaft output?
Old Apr 11, 2006 | 10:23 PM
biglee's Avatar
biglee
Audio specialist
i think there is a seal on the input shaft but getting to it is a nightmare!
Old Apr 11, 2006 | 10:26 PM
SafeChav's Avatar
SafeChav
There is indeed, and i think you are probably right
Theres one of the selector shaft too, supposed to be quite easy to change that one.
Old Apr 11, 2006 | 10:28 PM
biglee's Avatar
biglee
Audio specialist
the selector shaft gator is simple not sure on its seal tho i thought it was a bronze bush
Old Apr 11, 2006 | 10:53 PM
SafeChav's Avatar
SafeChav
No apparently behind the rubber gaitor theres a push in oil seal of the same sort. Ive got to change the one on my Orion as its started weaping, i haven't looked myself yet though.
rex647
Mar 6, 2022 06:20 AM
gingeRS
Sep 4, 2015 06:29 PM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
