Urgent, tech. question!!
Old Aug 1, 2004 | 11:53 AM
cossiemen's Avatar
cossiemen
Whassup
Default Urgent, tech. question!!
car=cosworth 2wd
Where too goes my earth from my brakecylinder unit?
where is the exact/correct place too connect this electrical cable?
thanks in advance
Old Aug 1, 2004 | 12:30 PM
cossiemen's Avatar
cossiemen
Whassup
does someone know where these wires/connections are for?
i'm talking about the saphh. 2wd cossie
this one is located at the front;
could this be the temperature sensor?
If so, where to mount it then???
and this one comes from the starter motor; don't know where to connect it, i dont even know why it's there and why it's for (NO, i dont remove it ) cant find anything about it in the Workshop manual
Old Aug 1, 2004 | 11:36 PM
cossiemen's Avatar
cossiemen
Whassup
Old Aug 1, 2004 | 11:50 PM
Alloy's Avatar
Alloy
I'm sure you could connect it anywhere, as long as it has a good earth.
Old Aug 2, 2004 | 08:34 AM
cossiemen's Avatar
cossiemen
Whassup
Old Aug 2, 2004 | 08:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the top pictures are the ice warning temperature sensor it mounts on the front of the lower crossmember (the one behind the front bumper), but doesn't really matter.
the bottom pic? this wire comes from the starter motor, or goes to the starter motor? sorry, i don't properly understand the question? the only connections that look like that as far as i can remember are the temp sender on the cylinder head, or more likely the oil pressure switch that is screwed into an adaptor on the turbo oil feed hose near to the starter motor.
what's your question on the brake cylinder earths? there are a couple of brown earth wirse that bolt to the hydraulic brake unit. these wires are part of the abs loom and are the earths for the abs motor and pressure switches and stuff. does that help you?
hope that helps.
Old Aug 2, 2004 | 09:23 AM
cossiemen's Avatar
cossiemen
Whassup
thought so but many thanks!
this wire goes to the starter motor.
it realy helped me; problem already solved
hope that helps.
many thanks for helping me sorting this out mate
you are the men !
Old Aug 2, 2004 | 09:24 AM
Spiky's Avatar
Spiky
have you got a wire on the OIL presure (under inlet manifold)
so u already have te small wire on starter mortor????
i'd u pm me after work, i can have a look for you
Old Aug 2, 2004 | 09:32 AM
cossiemen's Avatar
cossiemen
Whassup
Spiky, i don't have a wire on the OIL pressure at the mo.
i have already one wire on the starter motor and that's a black/blue coloured one.
the wire (brown/green coloured) i am talking about comes from the mainbeam and goes together with the black/blue coloured wire (black/blue wire is already connected to the starter motor!)
would be if you could take a look
Old Aug 2, 2004 | 09:37 AM
Spiky's Avatar
Spiky
i'ts probably for the oil pressure light in the dash then mate
but will check later
Old Aug 2, 2004 | 09:39 AM
cossiemen's Avatar
cossiemen
Whassup
Spiky,
okay, i'm gonna check if i find something to connect it too...
thanks mate
Old Aug 13, 2004 | 04:24 PM
cossiemen's Avatar
cossiemen
Whassup
well, did you checked it already mate ??
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
