standard boost
Old Apr 8, 2006 | 10:32 AM
smitsturbo's Avatar
smitsturbo
Default standard boost
what does a standard escort rs turbo series 1 boost sit at & whats the max you can put it up 2 without blowin or breaking things?
Old Apr 8, 2006 | 12:19 PM
cossie350's Avatar
cossie350
Im pretty sure its 7 psi 1/2 a bar standard, you will hit the boost limiter at 10psi unless youve got a hearts and diamond ecu then its 12psi but you wont have one of these on a series 1 unless its been changed
Old Apr 8, 2006 | 04:40 PM
smitsturbo's Avatar
smitsturbo
just what i want to heer but i thaught you get a hearts & diamonds ecu as standard? am i wrong if so where do i get 1 from?
Old Apr 8, 2006 | 04:48 PM
cossie350's Avatar
cossie350
Off a 90spec series 2 mate
Old Apr 8, 2006 | 04:53 PM
smitsturbo's Avatar
smitsturbo
what if i get my ecu chipped? or would it be even better if i got a series 2 ecu chipped & banged her in
Old Apr 8, 2006 | 05:39 PM
SafeChav's Avatar
SafeChav
You should retain your S1 ECU, the majority of series 2 ecu's also need a knock sensor and a temperature sensor to work PROPERLY, it will work but not as it should.
Old Apr 8, 2006 | 06:25 PM
antony215's Avatar
antony215
Escort Rs Turbo
If your planing on turning the boost up then it needs to be done by a tuner as you need the fuel done too or you will melt things
timsrs
22
Sep 24, 2015 08:14 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
