s2 starting problems from cold
Old Apr 6, 2006 | 09:10 PM
millybuzzin's Avatar
millybuzzin
Default s2 starting problems from cold
can anybody tell me how i can solve my problem, wen i start my car from cold it runs ok but as soon as i move off and then stop it does not want to tick over anybody know how to solve this. When the car is up to running temp it is fine it only stalls when it is cold could it be my aux air valve? help would be appriciated
Old Apr 6, 2006 | 10:49 PM
wrcescort's Avatar
wrcescort
Default Re: s2 starting problems from cold
could be ya cold start inj playing up or need co setting up proply
Old Apr 7, 2006 | 03:49 PM
millybuzzin
Default thanx
how ordered a new aux air valve will try that and the cold start inj
Old Apr 8, 2006 | 12:42 AM
SafeChav's Avatar
SafeChav
Hello mate
Firstly, don't do anything with the cold start injector, once the cars running it does nothing. It sounds like you have an air leak to be honest, what does the car idle at? Once its stalled, if you restart does it idle ok? Have you started it and left it idling to get up to temperature before you drive off?
Old Apr 8, 2006 | 01:16 PM
millybuzzin
when car is warm it runs perfect 900rpm on tickover only when i start from cold does it not want to tickover.had mixture checked and is ok,was wondering if it could be aux air valve.when i start from cold i just drive off is that right or should i leave it to get warm.
Old Apr 8, 2006 | 05:20 PM
SafeChav's Avatar
SafeChav
I asked about starting it from cold just wondering. Start it up from cold and see if after about 1-2 mins it starts idling low and hunting. Its always best to let it run for at least a minute so before driving off, ideally let it get to temperature if you can, but thats not to do with the running but it will prolong the life of the turbo, as will let it run on before switch off.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
