what current does a fuel pump pull?
Old Apr 6, 2006 | 02:09 PM
Cowboi's Avatar
Cowboi
Default what current does a fuel pump pull?
just found a switch laying about, its good for 10 amps on 12v dc.
just wondering if this is any good to use with a fuel pump
Old Apr 6, 2006 | 02:12 PM
Cowboi's Avatar
Cowboi
by the way, just a standard fuel pump from an gte vauxhall nova.
nothing special and not a big spec engine or anything
Old Apr 6, 2006 | 02:29 PM
Phil's Avatar
Phil
Jeebus
Cold always use a relay circuit just to be sure
Old Apr 6, 2006 | 02:46 PM
Jim Galbally's Avatar
Jim Galbally
as per phil
Old Apr 6, 2006 | 03:47 PM
Eagle's Avatar
Eagle
Super Moderator
how about an 044 pump ????
Old Apr 6, 2006 | 03:50 PM
jon@work's Avatar
jon@work
IIRC, Stu said they draw about 18A max
Old Apr 6, 2006 | 06:56 PM
DazC's Avatar
DazC
Default Re: what current does a fuel pump pull?
Even a standard pump will probably melt that switch into your dash board, unless the heat build up in the switch causes your pump to slow and melt the engine first...
I'd expect the standard pump to draw about 14 amps.
Old Apr 6, 2006 | 09:05 PM
Cowboi's Avatar
Cowboi
ok. cheers guys.
i'll use the switch for something else that will cut the engine off.
Old Apr 7, 2006 | 03:10 PM
Eagle's Avatar
Eagle
Super Moderator
cheers mate ... so my 70 amp relay is a bit excessive then
Old Apr 7, 2006 | 09:02 PM
DazC's Avatar
DazC
I can supply you with a 180A relay so you can run 10 044 pumps if you want?
I can even supply you with a 2500 amp relay but it's huge!!!
Rod-Tarry
237
Mar 18, 2016 09:13 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
