Help needed with oil pressure.........
Right ive just picked my new cossie up and when it is ticking over the oil light comes on so i checked the oil level and it is just under the max so its not that but i noticed when it was ticking over the oil pressure gauge is only reading 15psi and go's upto 40-50 psi when driving.............
Is this ok or should it be higher the car is a 2wd saff and the oil was hot
First things first - try changing the oil and filter - i reccomend a genuine motorcraft filter, and Silkoline Pro-S 10W/50 - this shoiuld give you a hot idle of between 20 and 30psi at approximately 70 celcius oil temp.
At the moment, i'm using Pro-S 5/40 as the weather has been freezing, but the hot idle never goes below 20psi at 850rpm, and fast running (above 2500rpm) is always between 55 and 60psi when hot
ticks over about 850-900rpm i still get 50psi when driving never took any notice what it was from cold i was to busy looking around the car.....hope i do not have to pull the engine out already only done 20miles in it
ill change the oil and filter tomorow and try that first
not sure what oil is in it but i know it has just had a 200 block with low comp put in it as the old engine put a rod through the block so it may be on cheap oil.....would this make a differance????not sure it the low comp bit is true though could i check with my comp tester?????
ALL HELP IS MUCH APPRECRATED..
your supposed to run a fresh engine on a cheap mineral oil to bed the piston rings in. So the oil could be the cause of a lower oil pressure. I would get the run in period / mileage done then put a decent oil in (not Castrol RS LOL) and see what the pressure is then.
cheers...... cossie4i...... i was just working that out but mine is no were near that hope it dose not need a new oil pump
not when i just bought it i need to have some fun first
was the oil pump not changed when the rebuild was done?
the pump only provides the flow, not the pressure
IMO 50 psi on stone cold isnt enough mate..
the pressure comes form the oil being forced into small places like, bearings cooling channels etc..
as these wear and increase in size it becomes easier for the oil to get in and hence reduces the oil pressure..
i see almost 80 psi on idle if its been lying over nite.
As said above,start with the basics,good oil/filter etc
Could be a dodgy/cheap gauge
Get pressure tested at a garage with a proper pressure tester if your really worried
If the worst comes to the worst an oil pump is a lot cheaper than a re-build m8,not worth giving it any grief if you suspect the pump
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
