Plastic Welding
Old Apr 4, 2006 | 11:24 AM
Ryan's Avatar
Ryan
Default Plastic Welding
Any tips
Or stuff to use?
Want to do some bodykit repair, i.e screw holes that have pulled through, so i want to fill them and redrill.
Ryan
Old Apr 4, 2006 | 11:27 AM
GARETH T's Avatar
GARETH T
depends on what the bumpers are made from
fiberglass and resin is fine
Old Apr 4, 2006 | 11:30 AM
Ryan's Avatar
Ryan
its not bumper gareth, its the arches and sideskirts.
bacislly you know where they are pop riveted onto the shell, well where they've been on and off a few time and poorly rivets the holes has been crushed and pulled through (hole is about 5-6mm)
so i want to fill these in and redrill the rivet holes.
Old Apr 4, 2006 | 11:38 AM
GARETH T's Avatar
GARETH T
i got you mate,,, plastic welding would really be that nice one a hole that small
fiberglass and epoxy i say
Old Apr 4, 2006 | 01:04 PM
Ryan's Avatar
Ryan
how could i fibreglass a hole what small gareth?
surely some melted plastic would be easier?
Old Apr 4, 2006 | 07:45 PM
Damo V's Avatar
Damo V
Have a look at this, I use both these kits, IMO the heat will be better for you in this instance...
http://www.glassaid.co.uk/plastic.html
you will also need some aluminium reinforcing mesh, they should sell it...
Just make up some bollox about starting a SMART repair business and need stock etc... They will believe you as every other SOB is
Old Apr 4, 2006 | 07:54 PM
jacko's Avatar
jacko
olot of the ford plastics wont weld it just moves away from the heat and burns , so the best thing to use is the plastic fillers and fill the hole then sand it flat i did some of the pop rivet hols on the sills of a 3 door iv just restored useing worth industries flexable plastic adesive resin and it works fine
Old Apr 4, 2006 | 08:05 PM
Damo V's Avatar
Damo V
Dunno if I would just use a flexible filler TBH... Granted some plastics dont like heat, in that instance I would use the cold weld (polyurathane) kit.... Perhaps thats what the Wurth product you mention is?? Does it mix two parts together via a mixer tip, like araldite?
Old Apr 4, 2006 | 08:11 PM
jacko's Avatar
jacko
yes mate it is as you say more of a cold weld but its what werth call it iv used it on loads of ford kits and it works fine it dosnt crack out goes of in seconds and is as flexable as the plastic and can be sanded to a nice finish as easy as caty can and best of all you dont have to buy expensive kits just the one tube , iv tried lots of this tipe of material over the years including image plast and dura mix but i find the worth stuff is better
Old Apr 4, 2006 | 08:12 PM
Damo V's Avatar
Damo V
Old Apr 5, 2006 | 01:00 PM
Mike1's Avatar
Mike1
Do you know where you can get this worth/werth(?) industries stuff from? Is it mail order only?
Anyone know anything about the stuff from www.plastex-uk.com ?
Cheers for any info you can furnish
Old Apr 5, 2006 | 01:43 PM
Damo V's Avatar
Damo V
I have never used anything like the products in your link, Wurth are trade only, for something similar see the link I posted
Old Apr 5, 2006 | 01:58 PM
Ryan's Avatar
Ryan
jacko, fancy sending some down along with the arch?
Old Apr 5, 2006 | 04:00 PM
jacko's Avatar
jacko
ill get you some sorted mate no probs
Old Apr 5, 2006 | 04:56 PM
Ryan's Avatar
Ryan
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
