Commercial Workshop floor paint......
What's good to use?
Our new unit is just about ready. It currently has an unpainted concrete floor and we want to paint it with something that stands a chance of lasting more than 3 weeks.
Not on an open budget though.
Any idea's??
Any idea's??
Ive used Leyland heavy duty floor paint many a time, never needed more than two coats for a good long lasting and hard wearing finish. Dont forget to coat the floor with concrete sealer first also.
Christian,
Give us a ring at work tomorrow and i'll dig out the name of the last lot we used......
it was like arraldite wher you add the hardner, lasted fookin ages before it started to come off and even then its pulling the old paint from underneath off the concrete, so i bet it'd be awesome on a new unpainted floor....
Rob
Rob
The floor may have been power floated IE polished and paint will not stick to it. If it has not been power floated I would use a 2 pack Epoxy paint or even better a Epoxy screed
Hi m8
I am a Building Surveyor by day, and one of the main things I deal with is Dilapidations Schedules. I would just add a couple of things:
1) Are you leasing the unit or do you own it? If you are leasing the unit, check on your repairing obligations. If you paint an unpainted floor without llords approval, you may be asked to remove that paint back to the original unpainted finish when your lease expires. (this is unlikely). More likely, you will be expected to pay for it to be repainted on your last day of lease prior to vacation.
2) If you are painting the floor, you need to be sure that the paint you use is a dedicated floor paint system. If you use a non-approved system, and somebody slips, you will end up getting sued! Also, the cheaper paints will break up very easily when exposed to oil and fuel. To be honest the dearer ones will as well eventually, but be mindful that if you buy cheap and do often, this can end up being dearer overall.
Hope this helps
JJ
Hope this helps
JJ
hi christian.
we have just finished painting our climatic wind tunnel and workshop floors with a 2 pack epoxy paint that is superb. it's made by a company called Watco and is called 'epoxy gloss coat solvent free'.
goes on really easily with a roller (cutting in around the edges with a brush) and a 5 litre tin will cover 30 m^2 at a cost of about £100.
we chose a light grey that doesn't show dust much and reflects a lot of light in the work area.
needs a day to harden enough to walk on, but you need to leave it 7 days before it's fully chemical resistant, so plan ahead.
Orion_Gav
Sep 29, 2015 04:50 PM
