stage 3 price?
Old Apr 3, 2006 | 03:18 PM
escortrsmatt's Avatar
escortrsmatt
Default stage 3 price?
hi peeps, just wondering how much a stage 3 setup will cost me for my 4x4 sapph.was thinking of going to engine advantages if anyone has any experience with them?will need injectors, map sensor, chip and setup.cheers in advance matt
Old Apr 3, 2006 | 03:26 PM
DaveEscos's Avatar
DaveEscos
budget on around Ł500
Old Apr 3, 2006 | 03:43 PM
rapidcossie's Avatar
rapidcossie
can get all second hand stuff of ebay then get it to a rollers to check it out..
would be alot cheaper but not as safe
Old Apr 3, 2006 | 04:35 PM
Stu @ M Developments's Avatar
PassionFords Creator
Ł465 plus postage from me.
Chip, -31, 4x803's and a 3 bar map sensor.
All with full fitting instructions and after sales technical backup of course.
Old Apr 3, 2006 | 04:46 PM
escortrsmatt
will i not need to set up the fueling and boost using a rolling road if i buy this from you stu?
Old Apr 3, 2006 | 04:59 PM
graham c's Avatar
graham c
na set it up on the nearst road its save your self 100 quid put it 2 wards new tyres 4 the back
Old Apr 3, 2006 | 05:28 PM
I would recomed you get a friend with a wideband to check it out, like any mods to a turbo car, just in case you have some fault the kis supplier (ie stu) doesnt know about, like an inadequete fuel supply or similar.
But you dont need a rolling road.
Old Apr 3, 2006 | 05:35 PM
Danny @ Enhanced Performance's Avatar
we do stg 3 fitted and set up for 500 and we can check al sensors etc with pectel monitor
Old Apr 3, 2006 | 05:49 PM
I strongly reccomend you have the fuelling checked using a wideband fuel monitor on either rollers or better still the open road.
The fact my chip has asked your fuel injectors to open at 4000rpm and spray fuel at the inlet valve for 18ms at 5.3bar fuel pressure (1.8bar boost) does not necessarily mean your fuel pump supplied the fuel, the fuel reg regulated the pressure to 5.3bar or the wiring loom even asked the injector to open for long enough in teh first place.
If you follow what im saying?
Fully fitted and setup price for teh same kit is Ł565 but i realise your a long way from Blackpool for this relatively simple Job. Quite a few of my mail order customers from your area use Mark Shead for teh fitting and are always 100% happy.
Old Apr 3, 2006 | 05:54 PM
Dave Henshall's Avatar
Dave Henshall
you wont be unhappy mate,
i'd pay the little extra and have it checked over by someone like mark or stu,
for the sake of an extra 100 quid when it could cost u 2K for anew engine if it goes wrong, for all you know there might be a bodge jkob being hidden on the car by runnig std or stg 1 that will show up once u up the power,,,
Old Apr 3, 2006 | 06:00 PM
escortrsmatt
i def wont be skimping on the cost of setting up seeing as how much my engine rebuild has cost me!ideally i would like a live map but i have a few other money matters before i can afford that!if that isnt contradicting myself too much?!?!
Old Apr 3, 2006 | 06:10 PM
Alps Pacino's Avatar
Alps Pacino
I got mine done and set up by stu and was very impressed with the set up, car was smooth as silk and unbeliavebly the car was no worse on fuel than it was at stage1.
Going stage3 can show up signs that other components aint up for the job, when i got mine done they found out the fuel pressure reg wasnt up for the job, then i had to replace the cps and phase sensor as it developed a missfire.
So budget for a few more bits that might be up to the job of standard but show there weakness when pushed at stage 3
O and then the rebuild, mine has let go for the new owner and melted no4 piston for some reason, no fault of msd or there work, but the more power equals less reliability unfortunatly
Old Apr 3, 2006 | 06:27 PM
escortrsmatt
well im hoping mechanical reliablity shouldnt be an issue seeing as the only old components being used are the crank and rods of the bottom end and i bought and rebuilt a complete head!
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
gingeRS
17
Oct 2, 2015 09:42 AM
A.t.p
Sep 29, 2015 05:04 PM
