coilover fitting problem(4x4 Saff)
Old Apr 2, 2006 | 05:21 PM
Dean Saff's Avatar
Dean Saff
Default coilover fitting problem(4x4 Saff)
Just been fitting my new Avo coilovers, got the rears on so far.
Noticed that the rear nearside spring is very close to the inner arch and touches when compresed
Anyone had this problem? thought of bashing the inner arch in a bit to give clearence
Old Apr 2, 2006 | 05:39 PM
Azrael's Avatar
Azrael
That's exactly what you need to do, take a big hammer.
Old Apr 3, 2006 | 02:17 PM
velocity's Avatar
velocity
as Azrael says you will have to do this. this is a know problem and can happen when fitting coilovers to the saph.i had to do it my self last year.
just way off where its rubbing and give it a few belts in the area,
its only a small area that rubs and you dont have to use a sledge to do it. make sure you reprotect the area you have hit as it normally will expose some bare metal
Old Apr 3, 2006 | 06:19 PM
Dean Saff's Avatar
Dean Saff
Job done and in primer awaiting a quick lick of paint.
cheers fellas
Why dont they mention this when you buy the dam things
Old Apr 3, 2006 | 09:13 PM
Azrael's Avatar
Azrael
Theyusually do, and they say you need to have top mount reinforced. You have rear brace, don't you?
Old Apr 6, 2006 | 03:38 PM
Dean Saff's Avatar
Dean Saff
No
Old Apr 6, 2006 | 05:40 PM
Azrael's Avatar
Azrael
Dean Saff I think you should.... I had rear turrets stich welded and brace fitted.
JoeyBoyden
Jan 4, 2024 02:36 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
cossie4x4
Aug 14, 2015 06:29 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
