compression testing?
Old Mar 31, 2006 | 06:40 PM
rst in breaking's Avatar
rst in breaking
Default compression testing?
can a compression test be done with the engine cold because ive always letthe engine warm up, remove plugs, insert tester into plug hole and turn over? the only problem is this time is that i cant start my engine to do this but with the oil not thinning outthis causes a problem? is there another method i can use?
Old Mar 31, 2006 | 08:20 PM
AlexF's Avatar
AlexF
It has to be done hot...
why are you worried about the oil?
Alex
Old Mar 31, 2006 | 08:22 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Really?
Old Mar 31, 2006 | 09:32 PM
lawnsy's Avatar
lawnsy
It has to be done hot with your foot flat to the floor while you crank it over
Old Mar 31, 2006 | 10:03 PM
rst in breaking
Alex
because if the oilis thick it works as a seal on ur rings giving a false reading
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
