Anyone know nething bout vauxhall tigras??
Old Mar 31, 2006 | 03:42 PM
Turbo Pez's Avatar
Turbo Pez
Default Anyone know nething bout vauxhall tigras??
i know this is a ford site and i am a ford man, but i friend of mine wants a 2.0i 8v lump put in her tigra to replace the 1.4 lump in it, swaping the engines is not the proplem, its the wiring, i haven't really looked into it yet, just wondered if any knew if this is going to be a arse or easy as pie, before i start ripping out the old lump,
Guessing i would say the looms wud be pretty much the same!!
I wish i wasn't drunk when i said "i'll do it"
Pez!!
Old Mar 31, 2006 | 03:46 PM
paul16v's Avatar
paul16v
Monte 087
Putting a 2.0L 8v in a tigra is not that simple its a big block engine and the 1.4 is a small block, so its basically the same amount of work as putting a valver in a corsa/nova custom mounts etc
Old Mar 31, 2006 | 03:56 PM
Turbo Pez's Avatar
Turbo Pez
So might as well put a 16v lump in if its going to be a custom mount job!
Old Mar 31, 2006 | 04:02 PM
playgirl's Avatar
playgirl
my firend paul did it to his tigra, have a look on migweb there maybe some info on there, he had a fair amount of problems
Old Mar 31, 2006 | 04:08 PM
paul16v's Avatar
paul16v
Monte 087
Yup its exactly the same work to put the 8v in as it is the 16v xe motor, i can put u in touch with somebody who makes the mounts etc and can supply a disk detailing the conversion/wiring up if you would like.
Old Mar 31, 2006 | 04:15 PM
Turbo Pez's Avatar
Turbo Pez
Thats quality mate, i mite get that of you, just gota have agood think bout it 1st and make sure she wants it done!!
Old Apr 9, 2006 | 04:19 AM
GazzaG's Avatar
GazzaG
My dad had a vauxhall tigra and all it ever did was fall apart
hope hers is better lol
his was a M reg
Old Apr 9, 2006 | 04:53 AM
Benni's Avatar
Benni
Ban[B][/B]ned
Good looking cars are vauxhalls gaz.......So stevie wonder was telling me.
Old Apr 9, 2006 | 04:56 AM
GazzaG's Avatar
GazzaG
Old Apr 9, 2006 | 04:57 AM
Benni's Avatar
Benni
Ban[B][/B]ned
LMAO
Old Apr 9, 2006 | 07:59 AM
Kev.H's Avatar
Kev.H
i had a tigra for a week as a rental car and whenever you shut the boot the windows went down and it was like a mustard colour fecking annoying keep having to do the windows back up
Old Apr 9, 2006 | 09:54 AM
Diseasel's Avatar
Diseasel
Some guy on migweb has a 2ltr turbocharged Tigra iirc.
Old Apr 9, 2006 | 03:52 PM
GazzaG's Avatar
GazzaG
was allways the drivers one on ares lol plus they were electric ones
Old Apr 9, 2006 | 04:17 PM
jr's Avatar
jr
that was there, because when you slam the boot the vacume created by the large glass window use to blow the windows out on the very early cars, vaux put it in there to let the pressure out
Old Apr 9, 2006 | 04:22 PM
jr's Avatar
jr
as has been said, not alot of point putting the 8v in, as there down on power compared to the xe, very good engines though, butt gettign on abit like the xe
is easy enough to put in, but the engine has to sit about 30mm lower than the corsa/nova conversions because of the low bonnet/wing compared to the corsa etc
apart form that pretty simpel to do, LMF vauxhall sell the M_tech conversion kits, or theres quite a few people that make them, will need the shafts and a few other bits, only other thing your need for the xe is a inlet of some description, as the SFI box needs cutting and shutting to fit, most popular way is using the V _tuning inlet plate, which doest require anymodding to fit
Old Apr 9, 2006 | 04:24 PM
jr's Avatar
jr
Default Re: Anyone know nething bout vauxhall tigras??
Pez!!
considerd putting the 1.6 16v X16XE i it, much easier as its a direct swap, and with the adition of a manifold and inlet such as a Lexmaul or a Manztel your be around the 130bhp mark of the 2.0 8v
Old Apr 10, 2006 | 08:13 AM
Kev.H's Avatar
Kev.H
shouldnt they make em go back up
Rod-Tarry
237
Mar 18, 2016 09:13 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
CossieRich
30
Sep 8, 2015 10:08 PM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
warleydaddy
12
Aug 10, 2015 06:31 PM
